+ Reply to Thread
Results 1 to 13 of 13
Thread: coolant temp sensor needed?
02-07-2010 01:28 PM #1
crazy question prob but im making the guys harness for a obd0 ls and if i remove the coolant temp sensor (2 wire) n wiring will that affect the running of the car? ecu going crazy? i already deleted the fan switch (2 wired sensor on the t stat housing) and controlling the fan via a switch on the dash.
any info on the affects of removing the coolant temp sensor in regards on the ecu thinking the motor is cold/ or pulling timing....
02-07-2010 09:02 PM #2save the s.o.h.c
- Join Date
- Jul 2004
- Location
- tampa
- Posts
- 3,170
- Feedback Score
- 32 (97%)
the ecu needs to read the coolant temp. why would you want to delete the two and go with a toggle switch?
02-07-2010 09:11 PM #3
i didnt, the guy im building the harness for did, im gonna leave the clt sensor hooked up n delete the fan switch.
hes deleting the fan switch n going toggle bc that tricks called a .1 switch for a quarter mile run. turn the fan off save a tenth of a second on your quarter mile times compared if you had the fan on creating the alt to be on and creating a draw/ resistance on the motor
02-08-2010 11:30 AM #4.........................
- Join Date
- Apr 2003
- Posts
- 3,536
- Feedback Score
- 18 (100%)
R.I.P. Slo_si
02-08-2010 01:25 PM #5engine building &best
- Join Date
- May 2003
- Location
- i like pinkEye
- Posts
- 12,943
- Feedback Score
- 65 (100%)
^ i bet your not laughing as hard as i was when i read it
i love AUTOZONE
100+served in engines built from minime to gsr/lsvtec,b16 b20vtec,d15 rebuilds.life is good
i like when people don't take my advice.cause then i make more money u need to rebuild it the right way!
02-08-2010 03:48 PM #6CRAWFORD BUILT
- Join Date
- Mar 2009
- Location
- 2 miles ahead of you still pulling
- Posts
- 1,087
- Feedback Score
- 0
drawing power from the motor does effect your spark but if your drag racing then your probably running an MSD or something similar where it's sending so much power to the plugs that it doesn't matter if the fan is on or not.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
02-08-2010 04:15 PM #7
ZOMG!!!
02-09-2010 09:56 AM #8
what the hell dose a msd have anything to do with compensating for draw created by the alternator? if your sitting still w your car idling and your fans turn on or ya turn your headlights on your cars idle drops. idk its a pretty simple concept.
laugh all ya want, id call it more or less common sense
02-09-2010 10:46 AM #9CRAWFORD BUILT
- Join Date
- Mar 2009
- Location
- Posts
- 1,087
- Feedback Score
- 0
^ your spark has less power when accessories are on...
CRAWFORD BUILT
DC Crew Member #23
02-09-2010 02:13 PM #10
ok, well back on topic, laugh n think what ya want but its a valid point to keep your fan off during a pass to have less resistance thru your alternator thus reducing drag on your motor.
02-09-2010 02:50 PM #11engine building &best
- Join Date
- May 2003
- Location
- i like pinkEye
- Posts
- 12,943
- Feedback Score
- 65 (100%)
if your having that much trouble with your power buy a aftermarket slim fan it uses less amprage so you will be ok on not lossing power
i love AUTOZONE
02-09-2010 03:32 PM #12
Have him just unplug the fans from the harness before he runs.. Saves you time and trouble..
SEE NO EVO HEAR NO EVO!
If i put half a tank of Shell V power, and half a tank of Chevron with Techron. Will i get v-tec??
02-09-2010 03:51 PM #13
already have it wired up to a toggle on the dash
Thread Information
Users Browsing this Thread
LinkBack URL
About LinkBacks
