Harness Questions?? Please Help (PICS)
Old Jul 17, 2009 | 01:00 PM
mr.hatch's Avatar
EKallday
Default Harness Questions?? Please Help (PICS)
Harness Wires (PICS) - Honda-Tech
Old Jul 17, 2009 | 01:19 PM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
Buy a new/uncut/unfuckedup harness, or contact the guy in your sig that seems to offer custom wiring .
-Winston Churchill
Old Jul 17, 2009 | 03:14 PM
StreetBlitz's Avatar
B Tuned CRX
wow, that body harness is in BAD shape. Best bet is to go to a junk yard and pull one in better condition. OR... if all the plugs/pins are intact, get a helms wiring diagram for the body harness, and make a new one with some shielded wire.
Old Jul 17, 2009 | 08:20 PM
60-1EK's Avatar
Engineer at the source
Seriously.....looks like a$$. Get a new one or send it to me and it will cost you more.
www.helminc.com will also help you.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Jul 21, 2009 | 08:35 AM
mr.hatch's Avatar
EKallday
so besides buying a new one nobody has a clue
Old Jul 22, 2009 | 12:06 PM
Nandosol's Avatar
Garage Slut
1) Get a wiring diagram
2) Rewire harness, re-pin connectors
Oh yea WTF is your question?
That might help
All I see is pics of a fucked up harness. You can barely see the colors from all the hacked up wires added on there. The best bet is for you to get a wiring diagram, or buy a new harness. exit
Old Jul 22, 2009 | 12:14 PM
Jun_Tuning's Avatar
VTEChnician
i can fix it that shit is cake work, i've done worst wiring jobs, i will ex-plane how to fix it in a new post
HYBRIDWORKS
Performance Inc.
Repair shop / E-Tailer
"TR Member Discounts Available"
About Us
[/SIZE]
TR "Old Skool EF" Crew - Member #126
We Buy OBD1 Honda ECU's
Non-VTEC:$20-up
VTEC:$40-up
ECU'S WE BUY: P28, P06, P72, P75
Old Jul 22, 2009 | 01:31 PM
Jun_Tuning's Avatar
VTEChnician
ok now here we go, this is a dx harness, who ever did the conversion did it messy, hope you know how to count the plug by the numbers im saying
http://hondacrx881.tripod.com/mpfiswap.html
parts you would need to fix this
  • Car battery
  • test light
  • solider
  • Heat shrink
  • Black tape
  • roll of wire
The red and yellow wires are injector wires, those depinned wire are not to be in use, Pin slot A3 the red wire that is heat shrinked is injector #2 run that wire into the engine bay and mark it as injector #2, Pin slot A7 the yellow wire you see heat shrinked is injector #4 now run that wire into the engine bay and mark that one as injector #4
the white/red wire is C1 is for the crank position sensor in the disributor, mark that Blu/grn and run it to the engine bay, the red/yellow wire is C2 run it to your engine bay and mark that as Blu/yel
Red and black wire are for the fog on side the corner light
the green and black wire go's to the secondary pump on the washer fluid tank
HYBRIDWORKS
Performance Inc.
About Us
[/SIZE]
Non-VTEC:$20-up
VTEC:$40-up
Old Jul 22, 2009 | 11:25 PM
Rep for you.
Thanks for helping a member out with his wiring and pictures.-Bob
Old Jul 23, 2009 | 07:28 AM
Jun_Tuning's Avatar
VTEChnician
Originally Posted by senor honda
Rep for you.
no problem
HYBRIDWORKS
Performance Inc.
About Us
[/SIZE]
Non-VTEC:$20-up
VTEC:$40-up
