need d16z6 rod bearings torque specs
heres every torque spec possible for d series motor
ALL TOQUE SPECS ARE IN FT-LB.
A/T Tranny Drain plug...........................29
M/T Tranny Drain and fill plug..............30-40
Wheel Lug Nuts....................................80
Fuel Filter
Banjo Bolt............................................16
Service Bolt...........................................9
Clamp Bolt.............................................9
Valve cover Bolts....................................7
Spark Plugs..........................................13
Cam Gear Bolt.......................................27
Cam cover crown nuts..............................7
Crank(vibration) damper bolt....................119
Cylinder Head Studs....................1st step..22...2nd..49
Flywheel Bolts M/T..................................76
Drive Plate bolts for A/T..........................54
Header Bolts to Cylinder Head...................22
Header to downpipe bolts.........................33
Intake Manifold Bolts...............................16
Oil Pan bolts...........................................9
Oil pick up tube bolts...............................17
Oil Pump to engine block bolts/nuts.............9
Oil Pump Screen bolts...............................8
Oil pump cover Screws..............................5
Oil filter Housing Bolts...............................9
Rocker arm shaft pedestal bolts.................16
Rocker arm shaft end caps bolts..................9
Timing belt adjstment bolt.........................31
Rod Bolts............................................. ...............23 <---------
Main Bearings cap bolts
Separate caps and bridge...........................48
One piece cap assembly.............................33
Water pump pulley bolts..............................9
Thersmostat housing bolts...........................9
Water pump attaching bolts.........................9
Fuel injection service bolts
88-90................................................ .......9
91up.............................................. ..........11
Throttle Body nuts.....................................16
Fuel Rail nut............................................... 9
Manual Transmission
Countershaft locknuts................................65
End cover bolts..........................................9
Selector arm holder bolts.............................9
Tranny case to Flywhee housing..................20
Tranny to engine bolts
4 speed............................................. ........33
5 speed............................................. ........50
Clutch pressure plate bolts...........................19
Release fork bolts........................................22
Driveaxle/hub nuts.......................................134
Brake hose to caliper banjo bolts (front/Rear)...25
Master Cylinder Mounting nuts.......................11
Brake Booster mounting nuts..........................9
it has the rod specs too - save this list for future referencing...
i also have specs for rod bearing sizes as well... just let me know if you need them!
good luck!! - Jason
Fuel Filter
Manual Transmission
good luck!! - Jason
