TURBO: Stock Flywheel vs. 8lb Lose Torque?
Old 03-08-2006, 05:06 PM
once your bit, your done.
BitbyStreetRacin's Avatar
I guess Ill just make up for the light flywheel with more boost =)
Old 03-08-2006, 06:06 PM
could be worse
TIM TIM TIM's Avatar
boom
I have been debating on what to do with a flywheel.. its boosted, im guessing 250ish at the wheels now but want to get in the upper 3's..
aim:because tim said
Old 03-12-2006, 05:04 PM
clean teg's Avatar
when you install a lightened flywheel you lose the ablitly to store energy not lose torque i called fidenza and talked to a rep the way he put it take a 6 pound bowling ball and then a 18 pound bowling ball throw them from the same distance the out come at the end when the ball strikes somthing will be differant his example was a bowing ball and pins he said he get this question a lot we custumers can not spin or curp 2nd hope this helps
Old 03-12-2006, 05:54 PM
Can you spot me 20 cars?
qitstrn's Avatar
8lb flywheel is too light. i run the 11lb. You lose too many rpms between shifts if your flywheel is too light.
Old 03-12-2006, 09:23 PM
That ginger...
SmokinS13SR20's Avatar
I woulnd't really get a lighter flywheel unless I was having problems with wheelspin.
So if you have traction problems get a lightweight flywheel?
Old 03-12-2006, 09:25 PM
  #17 (permalink)
Zxc4's Avatar
negative ghostrider
Old 03-12-2006, 09:47 PM
  #18 (permalink)
Drivermod03's Avatar
+1....I went from a stock flywheel to a light one and I hated it...Seemed like I was short shifting cause the motor would kinda bog between gears..I liked stock better..
Old 03-15-2006, 05:09 AM
  #19 (permalink)
No "V-TECH" here!!!
SloCxHatch's Avatar
real men dont hardly lift there foot off the accelerator... in fact my 2nd to third and 3rd to 4th shifts i hardly pull off.... i have an 8 pound and i like it.... seems to work ok i mean 11.6 is not to shabby....
You can find me at the Track!
KJ built
ALPHA TUNED
Induction Performance 727.505.1423
* Engine Management Tuning, Track Setup, Consultation, Turbo Sales, Parts Sales (WorldWide)
ONLY SHOP IN TAMPA THAT TREATS YOUR CAR AS THEIR OWN
Old 03-15-2006, 07:15 AM
  #20 (permalink)
March2010 ROTM
skunkdSiR's Avatar
get the ACT 11lbs flywheel.. i got it on my setup and that bitch works wonders!!!
