+ Reply to Thread
Results 1 to 15 of 29
01-24-2012 08:08 PM #1Registered User
- Join Date
- Apr 2011
- Posts
- 245
- Feedback Score
- 2 (100%)
$3000 Fully built Turbo motor+Full Turbo Kit+Extras= One quick car!
Will sell as a whole lot...Almost everything you need to bolt in and go, all you will need is a head gasket & timing belt!
Added Pics Below!
D16z6 Block- New oil pump, New Water Pump, New Oil pan gasket, OEM bearings, tapped Oil Pan, with Vitara Pistons and Eagle Rods with ARP rod bolts.~~ 0 miles $450 Sold
D16z6 Head with vtec solenoid, Ported and polished, SuperTech Springs, SuperTech Titanium Retainers, Wrinkle Black valve cover with new valve stem seals, valve guides and valve cover gasket.~~0 miles $350
JDM D15B Tranny, shifts like butter, With OEM LSD (Super Rare) had 85,000 miles when pulled. $350
EXTRAS:
Skunk2 Pro Intake manifold, ported runners to head, opened TB to 68mm, painted wrinkled black to match~~ used $150
OMNI 68mm Throttle Body~~ new $80
Zex 59300 Comp Cam~~ Brand new in box with cam card $225
AEM (Black Series) Adjustable Cam Gear~~ new in box $80
RC 750cc Injectors with Pigtails~~used $150
ARP Head Studs~~ new in box $80 Sold
Competition Stage 4 Clutch ~~ Brand new in box $280
Competition Ultra Lite 9 Lb Flywheel~~ new in Box $185
T4/T4 57Trim Turbo~~ Brand new~~0 miles $125
Oil feed line/Return Line Kit~~brand new $40
Mini-Ram Turbo Manifold w/38MM wastegate opening~~Brand new$115
38mm Wastegate with 7psi spring & Dump tube~~Brand new $60
3 inch DownPipe with flex section~~Brand New $85
FMIC 28x6x3 (2.5 inlet and outlet)~~Used $100 with piping
Intercooler Piping (2.5 inch) with Greddy Flange painted wrinkle black with misc couplers~~used
Greddy Type-S style BOV~~used $55
AEM Digital Boost Guage~~New in Box $125
AEM Uego WideBand Gauge~~New in box. $150
All the bolts/gaskets/fittings to put in car.
ALSO.....
Brand New Supertech 10.5:1 75.5mm Pistons (Was going to go high comp, high boost instead) $300
Also have a spare Cast t3/t4 manifold with 38mm wastegate and a 90 degree, 3 inch downpipe. $60
JDM D15B ShortBlock 85,000 miles when pulled (unknown condition, looks good tho) $50
Like I said, everything needed to put in except timing belt and Head gasket! If your wondering why I am getting rid of it, Wanting to get a 1000cc + sportsbike. Also have a black 1994 Civic EX coupe (150,XXX miles), with the Walbro 255 LPH fuelpump in it. It runs, doesnt smoke, has cold A/C & PS. Currently has a High Comp Z6/Y7 (10.3:1) mini me with I/H/E (2.5 inch) and a virgin P28 that can be used to tune it with. Full Matching interior with CD Player, lowered on Tokico Blues and Neuspeed Springs with energy suspension shifter bushings. Currently sitting on black 18 inch rims (I know,I know) gonna need tires. Has mud flaps also. Cost me $4,159.96 in Parts alone without machine work and the motor itself, can provide most the receipts if necessary.Last edited by Sol Flavor; 01-29-2012 at 07:20 PM.
01-24-2012 08:39 PM #2
No sleeves = no fully built motor
Oh my B its Tampa fully built!
01-24-2012 09:06 PM #3
What brand is the mani and gate?
01-24-2012 09:10 PM #4
And turbo?
01-24-2012 10:30 PM #5Registered User
- Join Date
- Dec 2004
- Location
- tampa
- Posts
- 874
- Feedback Score
- 2 (100%)
Pmed
01-25-2012 05:44 AM #6Registered User
- Join Date
- Apr 2011
- Posts
- 245
- Feedback Score
- 2 (100%)
Yes I am going to part everything out if the 3 people that wants everything falls thru. I will post pics and price of all items once i start to part them out. As Stated most Items are new and in the box. I will not open the items that are cellophane sealed so that If i can not sell them locally, I will put on ebay or see if I can return them.
I will take pictures and post later today off all the items. (except head which is still at machine shop, I still owe them $100 to get it out for P&P)
01-25-2012 06:59 AM #7Registered User
- Join Date
- Apr 2011
- Posts
- 245
- Feedback Score
- 2 (100%)
I currently have 3 offers... 1 cash, 2 Streetbikes. If offers fall through will part out.
D16z6 Block..... 0 miles...$450
Head (pics coming soon)..................... $350
Skunk2 Intake Manifold with gasket........$150
OMNI 68mm TB w/gasket......................$80
Zex 59300 Comp Cam...........................$225
AEM Adjustable Cam gear.......................$80
RC 750cc injectors.................................$150
ARP headstuds......................................$80
Competition Stage 4 Clutch kit..................$280
Competition UltraLite 9 lb Flywheel............. $185
Oil feed/Return line kit...............................$40
SuperTech 75.5mm 10.5:1 pistons with rings....$300
AEM Digital Boost Gauge................................$125
AEM Uego Wide Band.....................................$150
38mm WasteGate......................................... $60
38mm Dump Tube set....................................$35
3 inch down pipe with flex section (5 bolt).......... $85
Mini-Ram/Ram horn manifold w/38mm wastegate opening............$115
T3/T4 T4OE .63A/R 57trim turbo............................................. .......$125
Cast t3/t4 manifold with 5 bolt, 90 degree DP....................................$50
Intercooler & piping (intercooler mounted on car)...............................$100
Greddy Type-S style BOV............................................... ................$55
EX civic....Yes I know the car is Dirty!! Car has A/C & PS. Will need 1 tire tho (Drivers rear is Flat). Has a y7/z6 mini me with a High comp Head gasket (10.3:1) It has I/H/E and a walbro 255 FP. Lowered with Tokio Blues and Nuespeed Springs and an Energy Suspension Bushing Kit on the shift Linkage. Could use a paint job as well. $2200Last edited by Sol Flavor; 01-27-2012 at 05:46 PM.
01-25-2012 07:00 AM #8Registered User
- Join Date
- Apr 2011
- Posts
- 245
- Feedback Score
- 2 (100%)
Will not part out yet!
01-25-2012 08:24 AM #9AKA DICK FITSWELL
- Join Date
- May 2008
- Location
- UNDER YOUR SKIN
- Posts
- 1,943
- Feedback Score
- 15 (100%)
Ur not outing it in the del sol? Thxs again for the headers.glws
camo krew
IM SO JDM I GOT A ASIAN GIRLFRIEND..BAHAHAH
01-25-2012 01:02 PM #10Registered User
- Join Date
- Jun 2010
- Location
- Clearwater
- Posts
- 395
- Feedback Score
- 1 (100%)
Give me a call 813-562-6546
01-25-2012 01:39 PM #11Registered User
- Join Date
- Jul 2005
- Location
- Lakeland
- Posts
- 5,165
- Feedback Score
- 101 (100%)
I am interested in a big item. If you decide to part out call me asap at the number in my sig. Thanks
Vance @ 863-604-2139 for any questions
01-26-2012 08:11 AM #12Registered User
- Join Date
- Feb 2009
- Posts
- 1,607
- Feedback Score
- 9 (100%)
ILL GIVE YOU $1000.00 FOR LISTED BELOW TO THE t.. let me know
727-271-7948
OK I NEED SUPERTECH 10-5-1 PISTONS FOR SOHC
I NEED D15B SHORTBLOCK-
I NEED INJECTORS 750s
I NEED ARP HEAD STUDS-
I NEED CLUTCH ASSEMBLY(NOT FLYWHEEL)STOCK IS BETTER TO ME
I NEED YOUR FULLY BUILT HEAD-
I NEED CRANE CAM
I NEED YOUR AEM WIDEBAND-
THIS ADDS UP TO BOUGHT 1300 BUT HOOK ME UP FOR BUYING IN BULK.Last edited by diamond101; 01-26-2012 at 11:23 AM.
01-26-2012 02:41 PM #13Registered User
- Join Date
- Apr 2011
- Posts
- 245
- Feedback Score
- 2 (100%)
I will let you know... but Prices are pretty much Firm. I have the receipts for the items above.
Clutch...... $315.00
ARP's........$110.00
Cam..........$264.88
Pistons......$390.00
WideBand...$168.88
That comes to $1248.76 .
Not including the head that has $299.99 (have receipt somewhere) in springs & retainers, and a $250 port job. Which isnt including the cost of valve stem seals, guides & machine work. Nor the injectors & block (which block isnt a big deal).
I understand this is TR, but this isn't the only place I listed this stuff. So not in a hurry to sell off, so prices are firm. If you can find and show me a better deal than any of the things new (including shipping price) I will sell it to you for cheaper!
01-26-2012 02:45 PM #14
$1000 for the z6 long block
01-26-2012 03:06 PM #15
Thread Information
Users Browsing this Thread
LinkBack URL
About LinkBacks
1993 Honda Civic
