Lead into Gold? How about Water and CO2 into petroleum?
By Michelle Starr
Sunfire GmbH/R. Deutscher If we're going to make a move away from fossil fuels, it's not going to happen overnight; too much of our existing infrastructure and technology is based on coal and petroleum, which would take a lot of time and money to replace.
Sunfire GmbH/R. Deutscher However, synthetic fuels would be a good interim option, especially if they could be cleanly produced -- as Sunfire GmbH has done. The Dresden-based cleantech company has unveiled a rig -- the first of its kind -- that uses what it calls "Power-to-Liquid" technology to convert H2O and CO2 into liquid hydrocarbons -- synthetic petrol, diesel and kerosene.
The technique is based around the Fischer-Tropsch process developed in 1925, combined with solid oxide electrolyser cells (SOECs). The SOECs are used to convert electricity -- supplied by renewable sources such as wind and solar -- to steam. Oxygen is removed from this steam to produce hydrogen.
In the next step of the process, this hydrogen is used to reduce carbon dioxide (CO2) -- harvested from the atmosphere, precipitated at biogas facilities or gathered using waste gas processing -- to carbon monoxide (CO); and the resultant H2 and CO are then synthesised into high-purity fuel using the Fischer-Tropsch process. Excess heat from the process is then used to create more steam -- ensuring an efficiency rate, Sunfire claims, of 70 percent.
The rig, at this stage, is for demonstration and feasiblity purposes; its capacity for CO2 recycling is currently at around 3.2 tonnes per day, and it has the capacity to produce a barrel of fuel per day. The cost of designing and building the rig was "seven figures", half of which came from public funding received from the Federal Ministry of Education and Research.
"This rig enables us to prove technical feasibility on an industrial scale," said Sunfire CTO Christian von Olshausen. "It is now a matter of regulatory factors falling into place in a way which gives investors a sufficient level of planning reliability. Once that has occurred it will be possible to commence the step-by-step substitution of fossil fuels. If we want to achieve fuel autonomy in the long term, we need to get started today."
We Wrap Matte
11-23-2013 03:39 PM
We Wrap Matte
10-20-2013 11:31 PM
