+ Reply to Thread
Results 1 to 3 of 3
  1. #1
    Not Mad CoRDiTe has a reputation beyond repute CoRDiTe has a reputation beyond repute CoRDiTe has a reputation beyond repute CoRDiTe has a reputation beyond repute CoRDiTe has a reputation beyond repute CoRDiTe has a reputation beyond repute CoRDiTe has a reputation beyond repute CoRDiTe has a reputation beyond repute CoRDiTe has a reputation beyond repute CoRDiTe has a reputation beyond repute CoRDiTe has a reputation beyond repute CoRDiTe's Avatar
    Join Date
    Feb 2004
    Location
    Tampa, FL
    Posts
    10,636
    Blog Entries
    5
    Feedback Score
    1 (100%)
    What's the best way to Siphon gas from a GMC sonoma??
    What's the best way to drain or Siphon the gas out of a 94 GMC sonoma??? I don't see a drain plug to remove all the fluid from the tank? I've tried from the filter area, but I think I'm doing it wrong. I removed the line from the back side of the filter facing towards the gas tank, I put the car in the on position to turn the fuel pump on , pumped the gas pedal to create some sort of Siphon and it didn't work. Only what was still in the line would come out. I even tried holding down the gas pedal and still nothing. Any suggestions?
  2. #2
    now with ls1! badhombre has a reputation beyond repute badhombre has a reputation beyond repute badhombre has a reputation beyond repute badhombre has a reputation beyond repute badhombre has a reputation beyond repute badhombre has a reputation beyond repute badhombre has a reputation beyond repute badhombre has a reputation beyond repute badhombre has a reputation beyond repute badhombre has a reputation beyond repute badhombre has a reputation beyond repute
    Join Date
    Aug 2007
    Location
    Lakeland
    Posts
    580
    Feedback Score
    first off, on a efi vehicle, pushing the "gas" pedal goes nothing but operate the throttle blade. ecu controls fuel delivery via injector pulses while it's running.
    to answer your question though, you are on the right track with taking the line off and turning the key on. but it will only cycle the pump for a few seconds. what you can do, is locate your fuel pump relay and jumper it across the power and output contacts to continuously run the pump. if you have any questions about jumpering the relay, don't guess at it. look up a schematic on the relay pin configuration and do it accordingly. you don't want to be replacing an ecu or harness trying to get gas out of it
    http://i16.photobucket.com/albums/b21/dragnblazer/trans-am/4-1.jpg
  3. #3
    Join Date
    Feb 2004
    Location
    Tampa, FL
    Posts
    10,636
    Blog Entries
    5
    Feedback Score
    1 (100%)
    Quote Originally Posted by badhombre View Post
    +1 Thanks. I will look into this.
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
