lt1 stuttering problem
Old 08-24-2007, 06:44 PM
Oh its got tires
Itonlysmokesalittle's Avatar
Question lt1 stuttering problem
I just bought a 1994 camaro 6 speed lt1 with 78,000 miles that had been sitting a couple months without driving. It has an aftermarket intake, tb and mas.airflow sensor. The car has not been tuned since these parts where installed.
The problem is, when going through the gears , hard throttle or normal driving, the whole car studders and shakes and wont rev past about 4500 rpms. I know it has old gas in it and the check engine light came on when driving but goes off when you restart the car. When in full throttle, it is very hesitant and I know it isn't normal.
If anyone has had any experience with this problem or might know what it is/how to fix, I would be very appreciative. Thanks
Old 08-24-2007, 06:55 PM
gribblek's Avatar
clean your furl injecters and get a new fuel pump and filter good luck because with the few parts it has on it the car would not need to be tuned your disturbuter my be bad just a few suggestions
Old 08-24-2007, 07:11 PM
PSSHHH x2
Sneakin Deacon's Avatar
wow...so much for doing the easy stuff first huh?
go see what your code is. the computer stores it even if the SES light goes out. after that work from there. sounds like an optispark issue, but one thing at a time.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old 08-24-2007, 07:40 PM
1fast6
silver_t's Avatar
ck your codes !!!! it could be a # of things
pm me !! with more info
Old 08-24-2007, 07:45 PM
Resident Ginger Kid...
J@meson's Avatar
i would say possible opti problems
2005 Joe Gibbs Silverado # 0396
1988 Monte Carlo SS 5.3/T56 and too many mods.
2003 Honda 954RR
Old 08-24-2007, 09:39 PM
Oh its got tires
alright ill be doing that tomorrow, I really appriciate the help, im kinda dissapointed however becuase I spent all my money just to buy the car in the first place
Old 08-24-2007, 10:32 PM
PSSHHH x2
well the good thing is, its a 94...so you can check the codes with a paperclip.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Old 08-24-2007, 10:43 PM
Race Photographer
Mars_302's Avatar
put fresh gas in it for starters, 89 at least
Old 08-25-2007, 09:36 AM
Oh its got tires
I threw a whole tank of 93 in yesterday and it seemed to help i guess time will tell
Old 08-25-2007, 06:20 PM
z28arbne's Avatar
I would definately lean toward opticrap. That was my issue. I had the same issue about the 4500 rpm nonsense. I would top out at 70 mph. I would first pull the codes brecause my friends car had a bad ground on the block and it acted simular. Sooooo, check codes.
