nitrous on stock 94 LT1
Old 04-20-2004, 08:17 PM
blowed up
formula69's Avatar
Default nitrous on stock 94 LT1
hey just wonderin how much nitrous i coudl run on a stock 94 LT1.. internally it is completely stock and the engine has like just over 60,000 miles on it wet? dry? help me out
Originally Posted by 05general lee
im FAT!!!!
Originally Posted by Little Nicky
Scott is my body guard
T.R. $100,000 kill club member #002
Turtle crew member #2
Old 04-20-2004, 10:48 PM
LiLBuDDy1587's Avatar
i would say 125 dry, 100 wet
Old 04-21-2004, 04:04 AM
The Happy Mrs.
HerHotRod's Avatar
BigBadBuick should know
Old 04-21-2004, 04:23 AM
LT1's are slow!
Half Fast's Avatar
Originally posted by URFUCT
I would run a 150 wet shot.
+1
Old 04-21-2004, 04:42 AM
lt1boyd's Avatar
should handel 200 no problem, wet,gotta use colder plugs, make sure your opti is good with a tune up, may need to pull timing but it should take 150 without pulling any timing
Old 04-21-2004, 06:11 AM
Civic Racing eXperiment
24-7's Avatar
+1
Old 04-21-2004, 08:22 AM
ZDriver96's Avatar
Depends how long you want your car to last. And i disagree. You should pull 2-3 degrees of timing with a 150 shot. You run a 200 shot and you'll kill a 4l60E tranny. And will probably kill it on a 150 if u have the 4l60e. Thats about 550ft lbs of toque to the ground. I wouldnt run a 200 shot unless ur not worried about it breaking cuz the risk is too high.
150 should be ok.. Just do all the safety features and try and get dual stages for 75/75 shots to avoid the torque spike. Much less stress on the car.
Go two step colder plugs.
96 M6 Arctic White Z28
"SLOW LT1"
Blue 2005 Acura TSX
