+ Reply to Thread
Results 1 to 7 of 7
  1. #1
    grease monkey! williamb82 has  hit bottom,  and can only go up! williamb82 has  hit bottom,  and can only go up! williamb82 has  hit bottom,  and can only go up! williamb82 has  hit bottom,  and can only go up! williamb82 has  hit bottom,  and can only go up! williamb82 has  hit bottom,  and can only go up! williamb82 has  hit bottom,  and can only go up! williamb82 has  hit bottom,  and can only go up! williamb82 has  hit bottom,  and can only go up! williamb82 has  hit bottom,  and can only go up! williamb82 has  hit bottom,  and can only go up! williamb82's Avatar
    Join Date
    Oct 2003
    Location
    spring hill
    Posts
    3,728
    Feedback Score
    1 (100%)
    where can i get a replacement air compressor tank?
    my gas powered compressor has developed a pinhole on the bottom of the tank. i thought of just welding it up, but chances are as soon as it pressurizes itll just spring another leak soon if not imediatly. id like to just get a replacement tank for it. it is a 22gal tank. anywhere local in tampa that sells them? i just need the tank, nothing else. its prolly ~18in in diameter and maybe 2.5-3 feet long.
    http://www.cardomain.com/ride/2042690/1 black 84 supra, 7mgte, truetrac, bbk, etc.. more in the works
    http://www.cardomain.com/ride/2117186/1 blue 85 supra, beater
    http://www.cardomain.com/ride/2965297/1black 86. saved from the crusher! wicked setup on the way.
    http://www.cardomain.com/ride/2235741/1 64 chevy c10, finally getting a new body. woot!
  2. #2
    Banned FoxHondaRider has a reputation beyond repute FoxHondaRider has a reputation beyond repute FoxHondaRider has a reputation beyond repute FoxHondaRider has a reputation beyond repute FoxHondaRider has a reputation beyond repute FoxHondaRider has a reputation beyond repute FoxHondaRider has a reputation beyond repute FoxHondaRider has a reputation beyond repute FoxHondaRider has a reputation beyond repute FoxHondaRider has a reputation beyond repute FoxHondaRider has a reputation beyond repute
    Join Date
    Aug 2008
    Location
    North of Tampa, FL
    Posts
    4,174
    Feedback Score
    11 (100%)
    Harbor Freight?
  3. #3
    Registered User Aoshi has a reputation beyond repute Aoshi has a reputation beyond repute Aoshi has a reputation beyond repute Aoshi has a reputation beyond repute Aoshi has a reputation beyond repute Aoshi has a reputation beyond repute Aoshi has a reputation beyond repute Aoshi has a reputation beyond repute Aoshi has a reputation beyond repute Aoshi has a reputation beyond repute Aoshi has a reputation beyond repute Aoshi's Avatar
    Join Date
    Feb 2004
    Location
    jax, FL
    Posts
    3,134
    Feedback Score
    1 (100%)
    Unless that's a very old and expensive brand, chances are it's trashed. If it's anything from harbor freight, you should have gotten the warranty, otherwise it's probably just trash now. Best bet it to email the manufacturer.
  4. #4
    Registered User ibidu1 has a reputation beyond repute ibidu1 has a reputation beyond repute ibidu1 has a reputation beyond repute ibidu1 has a reputation beyond repute ibidu1 has a reputation beyond repute ibidu1 has a reputation beyond repute ibidu1 has a reputation beyond repute ibidu1 has a reputation beyond repute ibidu1 has a reputation beyond repute ibidu1 has a reputation beyond repute ibidu1 has a reputation beyond repute
    Join Date
    Mar 2008
    Posts
    633
    Feedback Score
    ^^ Good idea look up the model name and call them and see, I personally would just grind down the area and weld metal patches prime, paint and forget it.
    But there nothing like an old compressor they are built soooo much better then the new stuff. Ive had mine for nearly 18 years. 3-5 times a year I empty the tank. Just make sure your tank free from any water build up.
  5. #5
    Join Date
    Oct 2003
    Location
    spring hill
    Posts
    3,728
    Feedback Score
    1 (100%)
    its an old gas powered compressor (not harbor frieght) i got for free from a neighbor ~10 years ago. gas engine was bad, and it was OLD then. i put a honda engine on it and fixed the throttle control and it works great. the pin hole is on the weld where it starts/stops where an end tank is welded on. my dad, who has been a welder for 40+ years told me to just clean it up and tig the spot shut, that it was prolly just a weak spot in the weld due to it starting and stopping in that spot. ive looked inside the tank and dont see any rust, and there is never any water coming out when i open the drain valve. really dry air considering its a single stage compressor. i just need to get some mild steel filler rod. all i have is 308/309 stainless and 4043/5356 aluminum. usually use my mig for steel exhaust pipes and whatnot.
  6. #6
    Join Date
    Mar 2008
    Posts
    633
    Feedback Score
    It sounded like the bottom was rusting out on it. I would def fill in the hole with a tig if you use the mig just make sure its nice and penetrated.
  7. #7
    Join Date
    Oct 2003
    Location
    spring hill
    Posts
    3,728
    Feedback Score
    1 (100%)
    i was thinking that it was rusting out as well, but i looked closer and it is actually on the weld. and there is a lil bulge of weld right next to it and in the same spot on the other end tank. got to find some filler rod and fill it in. might just grab a piece of mig wire to use for the filler and just have to feed it fast.
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
