+ Reply to Thread
Results 1 to 9 of 9
  1. #1
    Guest 0HP930 is an unknown quantity at this point
    Join Date
    May 2002
    Posts
    Feedback Score
    Injector Sizing Calculator
    Along with all the other stuff I have been trying to figure out lately is what size injectors I will need for my FI mods.
    Since I know some of you are thinking about tweaking your injection systems I thought you might find the following resource helpful.
    Not only do they give you the scientific equations to estimate your FI needs but they also have a convenient calculator at the bottom of the page.
    http://www.rceng.com/technical.htm
    Enjoy
  2. #2
    I have fuzzy eyebrows HybridSS has a reputation beyond repute HybridSS has a reputation beyond repute HybridSS has a reputation beyond repute HybridSS has a reputation beyond repute HybridSS has a reputation beyond repute HybridSS has a reputation beyond repute HybridSS has a reputation beyond repute HybridSS has a reputation beyond repute HybridSS has a reputation beyond repute HybridSS has a reputation beyond repute HybridSS has a reputation beyond repute HybridSS's Avatar
    Join Date
    Oct 2001
    Posts
    4,480
    Feedback Score
    3 (100%)
    Yeah...saw that. I think those calculations are a bit conseravtive..although there is nothing wrong with that. Better safe than sorry when fuel is concerned. Mainly about the 80% duty cycle...I dont want to approach 100% but I am not afraid to run at 90-95% for short periods. If I were starting from scratch I would use exactly what they prescribe here. That way your guarenteed to have ample fuel.
  3. #3
    lifelong learner Matt Vassallo has a reputation beyond repute Matt Vassallo has a reputation beyond repute Matt Vassallo has a reputation beyond repute Matt Vassallo has a reputation beyond repute Matt Vassallo has a reputation beyond repute Matt Vassallo has a reputation beyond repute Matt Vassallo has a reputation beyond repute Matt Vassallo has a reputation beyond repute Matt Vassallo has a reputation beyond repute Matt Vassallo has a reputation beyond repute Matt Vassallo has a reputation beyond repute Matt Vassallo's Avatar
    Join Date
    Jul 2000
    Location
    New Tampa
    Posts
    8,576
    Feedback Score
    1 (100%)
    so wtf did you choose to go with anyways
    100% is for men
    ive never had one of my injectors stick open
    rest in peace tim.
  4. #4
    Join Date
    May 2002
    Posts
    Feedback Score
    Since the auxillary injector controller I just bought has a two injector harness and I am looking to go about 200 HP over what the stock system can handle it appears I will need 2 650 cc injectors.
    Anyone have a couple for sale?
  5. #5
    New Member Mr 2 is an unknown quantity at this point Mr 2's Avatar
    Join Date
    Jan 2001
    Location
    Tampa
    Posts
    893
    Feedback Score
    my 72lb(750cc) injectors seem to be right for me, but I have aready seen all these calculators
  6. #6
    member ghuey is an unknown quantity at this point ghuey's Avatar
    Join Date
    Oct 2001
    Location
    Holiday
    Posts
    22
    Feedback Score
    Also if the motor is supercharged you need to account for the horsepower it takes to spin the charger.For example,gsr 200 hp at the wheels should equal about 235 at the crank.But is actually closer to 255 at the crank.So you need to adjust for paristaic loss when figuring the size injectors you are going to run,I imagine the vehicles accessories should be figured in the equation as well..Maybe that is why rc's estimates seem a little high..
    ~Guy
    AE
  7. #7
    Join Date
    Oct 2001
    Posts
    4,480
    Feedback Score
    3 (100%)
    ghuey.....I now what your saying but I believe all that is accounted for. The HP figures are for the motor and the BSFC changes will approximate added losses or ineffiencies for supercharged or turbo motors. As for accesories I am not sure.
  8. #8
    Join Date
    Jul 2000
    Location
    New Tampa
    Posts
    8,576
    Feedback Score
    1 (100%)
    well it all makes sense that if you put the engine and only the engine on a chassis dyno or whatever it is called ( you know the kind that hooks straight to the crankshaft)
    that the calculations will probably alot closer to what they are in real life.. as for me i feel theres only three real sizes of injectors that must be needed.. or hell.. anybody can get away with 720ccss. they always seem to idle good with a good sequential ecu..
    rest in peace tim.
  9. #9
    Join Date
    May 2002
    Posts
    Feedback Score
    I agree with mattback since any good modern ecu can control FIs well enough to make a set of 750s run great on a motor that doesn't need even need half that much.
    Then again, the big injectors are usually more pricey so it makes sense from a financial and engineering standpoint to get a set matched for your max output.
    With so much controllable variance on a turbo it certainly makes sense to run bigger sizes than what you think you might need.
    If the cost is not much more I just may buy a set of 750s even though I'm calculating I can get by with a set of 650s so I have some extra fuel if I need it.
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
