+ Reply to Thread
Results 1 to 12 of 12
Thread: help!!!!!!!
  1. #1
    ridin high GearGrinder has  hit bottom,  and can only go up! GearGrinder has  hit bottom,  and can only go up! GearGrinder has  hit bottom,  and can only go up! GearGrinder has  hit bottom,  and can only go up! GearGrinder has  hit bottom,  and can only go up! GearGrinder has  hit bottom,  and can only go up! GearGrinder has  hit bottom,  and can only go up! GearGrinder has  hit bottom,  and can only go up! GearGrinder has  hit bottom,  and can only go up! GearGrinder has  hit bottom,  and can only go up! GearGrinder has  hit bottom,  and can only go up!
    Join Date
    Apr 2001
    Location
    Riverview
    Posts
    5,347
    Feedback Score
    3 (100%)
    bought a 96 camaro on wed. and on sunday it dies
    i think its the starter
    turn key and it started to turn over then i went to turn it again and a loud clicking noise happens
    from then on it just clicks
    i get power (radio-lights-and even power windows go down)
    someone help?
    is it the starter and if it is does anyone have one???
    Own an APBT? visit... www.mypitbullpro.com
  2. #2
    Cairey
    Guest
    nate seriously...get a mountain bike or something
    you have the worst luck
    sorry kid
  3. #3
    Join Date
    Apr 2001
    Location
    Riverview
    Posts
    5,347
    Feedback Score
    3 (100%)
    i know i have the worst luck
  4. #4
    FearThe4Doors
    Guest
    sounds like theres juice there.. just not enough to turn the starter.. enough to flip the relay though. Remove clean and tighten the cables on the battery. Check charge of battery. Although you may not be able to even wiggle a battery cable by hand.. it could still be loose enough to cause that problem.
  5. #5
    single and ready to mingl 98intrigue has a reputation beyond repute 98intrigue has a reputation beyond repute 98intrigue has a reputation beyond repute 98intrigue has a reputation beyond repute 98intrigue has a reputation beyond repute 98intrigue has a reputation beyond repute 98intrigue has a reputation beyond repute 98intrigue has a reputation beyond repute 98intrigue has a reputation beyond repute 98intrigue has a reputation beyond repute 98intrigue has a reputation beyond repute 98intrigue's Avatar
    Join Date
    Mar 2002
    Location
    Clearwater
    Posts
    836
    Feedback Score
    my car did this for about a month. everyone told me that it WAS NOT because of the battery...but come to find out my battery had no life left what-so-ever. check out that battery of yours.
    Ryan - 2010 40th Anniversary 370Z
    First top mount single turbo 370Z - 506rwhp @ 11psi
    Top mount single turbo build thread
  6. #6
    Join Date
    Apr 2001
    Location
    Riverview
    Posts
    5,347
    Feedback Score
    3 (100%)
    how could it be the battery???
  7. #7
    ~ST0N3D~ 5SlowRacer is an unknown quantity at this point
    Join Date
    Oct 2001
    Location
    Land O' Lakes, Lutz
    Posts
    Feedback Score
    My stang did this a couple of months ago check the positive battery cable. Mine was cut so many times it just decided it couldnt handle the charge anymore.
    85' Mustang GT 5.0 $1500 obo!!!
    03 FOCUS ZX3
    NICK
  8. #8
    The H N I C 4.6Power is an unknown quantity at this point 4.6Power's Avatar
    Join Date
    May 2002
    Location
    St. Petersburg
    Posts
    Feedback Score
    it doesnt take much to power the radio ext. but it does take a bit to turn the car over. i would try to jump it if you did not already and if that doesnt work look to the starter.
    Does that look normal to you?
  9. #9
    MILKMAN
    Guest
    Three posobilities...the alternator the battery or the fact that its a Camaroj/k My fiance has a 99 Sunfire with 44000 miles on it and i have already had to replace the alternator!
  10. #10
    Join Date
    Mar 2002
    Location
    Clearwater
    Posts
    836
    Feedback Score
    all my accessories worked. radio lights windows....the car just wouldnt start. i had aaa come out and give me a jumpstart and i had to get a new battery
  11. #11
    Rod Bearing Eater mpbiv is an unknown quantity at this point mpbiv's Avatar
    Join Date
    Apr 2002
    Location
    Orlando Area
    Posts
    27
    Feedback Score
    In order of likliness
    Scenario one: Battery screwed starters use a lot of amperage to turn a engine especially if it has a lot of cylinders. It wouldnt be unusual for everything else to work but the car wont start. Sometimes you will get a clicking noise from the relay or the starter but the engine will not turn over.
    Scenario two: Alternator died and your battery is just discharged. Jump it if it dies when you remove the cables than the alternator is the likely problem. Or if it doesnt die and you are daring enough you can remove the battery while it is running and if it dies then it is a alternator problem thats assuming your battery still has enough amperage to run the car but not start it. If niether of these actions make the car stop running than it is the battery.
    Scenario three: Starter is gone.
    Just from my experience its always best to start with the battery in this situation. In most cases it is not the starter its usually the battery or the alternator but mostly the battery.
    In your case it sounds exactly like a dead or dying battery. I had this happen to me once because whoever I bought my car from put a small lawnmower battery in it which eventually overtime was damaged from overcharging by a system made for a larger battery. It all happened one morning I went to start it got the same problem you stated clicking and all. Had it jumped ran fine so I got a new battery and no problems since.
    Sorry for the long explanation
    Patrick
    05 SRT-4: Daily Driver, 11.9@117.4
    88 Aries: 2.2L Turbo (Powered by Megasquirt II)
  12. #12
    Join Date
    Apr 2001
    Location
    Riverview
    Posts
    5,347
    Feedback Score
    3 (100%)
    thanks for the help
    but the car will not jump start
    we tried and she still made the clicking noise
    i called the guy who i bought it from and he towed it to his shop and is going to fix it in the morning
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
