+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
  1. #1
    Registered User BIGBOI has  hit bottom,  and can only go up! BIGBOI has  hit bottom,  and can only go up! BIGBOI has  hit bottom,  and can only go up! BIGBOI has  hit bottom,  and can only go up! BIGBOI has  hit bottom,  and can only go up! BIGBOI has  hit bottom,  and can only go up! BIGBOI has  hit bottom,  and can only go up! BIGBOI has  hit bottom,  and can only go up! BIGBOI has  hit bottom,  and can only go up! BIGBOI has  hit bottom,  and can only go up! BIGBOI has  hit bottom,  and can only go up!
    Join Date
    Nov 2005
    Posts
    881
    Feedback Score
    brake drums quick question
    I have an older model 25+ years truck. Drum is very rusted.
    After taking off the rim the drum "cover" with the studs connected should just fall off correct? There is nothing attaching it correct?
  2. #2
    Can you dig it? Boostin'Xr4 has a reputation beyond repute Boostin'Xr4 has a reputation beyond repute Boostin'Xr4 has a reputation beyond repute Boostin'Xr4 has a reputation beyond repute Boostin'Xr4 has a reputation beyond repute Boostin'Xr4 has a reputation beyond repute Boostin'Xr4 has a reputation beyond repute Boostin'Xr4 has a reputation beyond repute Boostin'Xr4 has a reputation beyond repute Boostin'Xr4 has a reputation beyond repute Boostin'Xr4 has a reputation beyond repute
    Join Date
    Sep 2006
    Location
    Florida
    Posts
    1,796
    Feedback Score
    1 (100%)
    Hammer. It's not secured by anything, but it's rusted and heat cycled on.
    One of these days when my time has come, You can take me back to where I'm from.
    Put me on a westbound train, An' ship me off in the pourin' rain.
  3. #3
    Join Date
    Nov 2005
    Posts
    881
    Feedback Score
    I thought so.. It is just soo rusted on.. I am banging it.. I don't know what else to try.
  4. #4
    Join Date
    Sep 2006
    Location
    Florida
    Posts
    1,796
    Feedback Score
    1 (100%)
    bfh.
  5. #5
    Race Photographer Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up!
    Join Date
    Nov 2000
    Posts
    43,533
    Feedback Score
    6 (100%)
    chances are you need adjust the brakes and loosen them up. There probably is now a lip on the edge of the drum and the brake shoes are catching that lip and not letting it slide off easily.
  6. #6
    Join Date
    Nov 2005
    Posts
    881
    Feedback Score
    what is BFH?
    I am going to try some heat in the center of it if I can find my torch..
  7. #7
    Join Date
    Nov 2005
    Posts
    881
    Feedback Score
    Quote Originally Posted by Mars_302 View Post
    I was thinking something like that.
    There is two nuts on the backside that look like the mounthing bracket for the shoe.
    Which one is the adjustment nut?
  8. #8
    Join Date
    Nov 2000
    Posts
    43,533
    Feedback Score
    6 (100%)
    no nuts. there should be a plug or a knock out plate you have to remove or knock out then you use a screw driver or adjustment tool and turn the adjuster back, Those two screws are probably for the wheel cylinder
  9. #9
    Join Date
    Nov 2005
    Posts
    881
    Feedback Score
    Okay, I found the rubber plub and seen like a rack and I pushed it "away" from the drum cover and it clicked several times..
    Is this the right direction I am going?
  10. #10
    Join Date
    Nov 2000
    Posts
    43,533
    Feedback Score
    6 (100%)
    nope, you are just tightening it, there is also a littlle plate or bracket you have to push outta the way. This prevents the adjuster from loosening up.
  11. #11
    Join Date
    Nov 2005
    Posts
    881
    Feedback Score
    check pm please.
  12. #12
    Join Date
    Nov 2005
    Posts
    881
    Feedback Score
    I am going to get some penetrating oil now at the store and try it.
  13. #13
    Join Date
    Nov 2005
    Posts
    881
    Feedback Score
    Okay. Tried the penetrating oil. Didn't work. There was two thread holes in there so I put a bolt in there and I broke it a little.
    This thing is just a pain in the ass stuck on here.
  14. #14
    Join Date
    Sep 2006
    Location
    Florida
    Posts
    1,796
    Feedback Score
    1 (100%)
    BFH stands for big fucking hammer, by the way.
  15. #15
    Join Date
    Nov 2005
    Posts
    881
    Feedback Score
    Quote Originally Posted by Boostin'Xr4 View Post
    hahah tried it.. I am going to try bearing puller or something tomorrow...
    I put a lot of penetrating oil on it..
    This thing is really rusted.
    I noticed it as without the protective cover that usually protects this I guess it is years of dirt, grime and rust.
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
