+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 25
  1. #1
    buildin' it Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute Empire has a reputation beyond repute
    Join Date
    Jan 2009
    Posts
    4,177
    Feedback Score
    diagnosing a blown head gasket
    What are some ways to diagnosing a blown head gasket that you can do from home?
    I don't have a leak down tester/air compressor. I was hoping to figure out some other ways to do it...
    It isn't smoking, but it is also full of water and not antifreeze.
    you pop the cap off of the radiator, and it bubbles, as if it is boiling, but it is overheating, so it could very well just be boiling...
    (its on a 97 jetta, so it isn't really on the radiator, it is on the fill tank... VW's are weird)
    no water in the oil
    no oil in the water
    no leakage down the sides of the block
    any ideas?
    thanks
  2. #2
    OH LAWD K20A2 has a reputation beyond repute K20A2 has a reputation beyond repute K20A2 has a reputation beyond repute K20A2 has a reputation beyond repute K20A2 has a reputation beyond repute K20A2 has a reputation beyond repute K20A2 has a reputation beyond repute K20A2 has a reputation beyond repute K20A2 has a reputation beyond repute K20A2 has a reputation beyond repute K20A2 has a reputation beyond repute K20A2's Avatar
    Join Date
    Aug 2006
    Location
    VTAKistan™
    Posts
    15,146
    Feedback Score
    5 (100%)
    Any coolant/water loss at all?
    Fans coming on? Thermostat working properly?
    There are countless things that could lead to a car over heating, check/replace the least expensive things first.
    Also check the cap, your coolant hoses, etc.
  3. #3
    Banned Puto has a reputation beyond repute Puto has a reputation beyond repute Puto has a reputation beyond repute Puto has a reputation beyond repute Puto has a reputation beyond repute Puto has a reputation beyond repute Puto has a reputation beyond repute Puto has a reputation beyond repute Puto has a reputation beyond repute Puto has a reputation beyond repute Puto has a reputation beyond repute
    Join Date
    Jan 2005
    Location
    Candy Mountain
    Posts
    10,491
    Feedback Score
    1 (100%)
    Your car overheating at idle, how long since you last put in a thermostat? Get your system pressure tested asap. Depending on the leak, you might need to have a new gasket or a seal additive put in.
  4. #4
    Installs & Fixes Anything senor honda has a reputation beyond repute senor honda has a reputation beyond repute senor honda has a reputation beyond repute senor honda has a reputation beyond repute senor honda has a reputation beyond repute senor honda has a reputation beyond repute senor honda has a reputation beyond repute senor honda has a reputation beyond repute senor honda has a reputation beyond repute senor honda has a reputation beyond repute senor honda has a reputation beyond repute
    Join Date
    May 2005
    Location
    around Tampa Florida, Paradise
    Posts
    6,426
    Blog Entries
    Feedback Score
    19 (100%)
    1.Look for differences in the spark plugs.
    2.Crank it over with the plugs removed to see if water spits out.
    3.Look for "chocolate milk" in the oil or water.
    ....and what those guys said...-Bob
    ---- on-site *Aftermarket* spring/suspension installations --- on-site impact wrenching---street lowering with your own stock springs...........
    Much more at Bob's Garage!
    http://www.tamparacing.com/forums/bo...ontact-us.html
    Have a great day! bobfixesitup@yahoo.com 813-839-4281 (24 hrs)
  5. #5
    Why so Miata? Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian's Avatar
    Join Date
    May 2004
    Location
    Venice, FL
    Posts
    8,688
    Feedback Score
    If you have a 7M, its very likely you have a BHG.
    Honestly it could be a radiator cap.
    ASE: Brakes
    I can get you Pampered Chef stuff. Just sayin'
    RIP JZDeLorean and Tyler
  6. #6
    Join Date
    Jan 2009
    Posts
    4,177
    Feedback Score
    just replaced
    the water pump
    the thermostat
    the radiator cap
    the radiator flows the way it should
    no leaks, until it over heats and the pressure builds up
    the heater blows hot while everything is ok, but as soon as the flow gets messed up, from what I was thinking was vapor lock, it stops blowing hot.
    the fans are wired to a manual switch so i could rule out the bad temp switch.
    you can fill it, run it. let it cool down, top it off, and drive it for 30-45 minutes without a problem. then the temp gauge will just raise and raise til it is pegged out. you get it parked, and pop the radiator cap and there is significantly less water, around 3/4 of a gallon. it takes just over 1.5 gallons to fill it.
    I was thinking headgasket because when you let it idle with the cap off, it bubbles, as if it is boiling. you can touch the water and it is warm, but not boiling hot. Then it warms up and just spits water all over the place. I was thinking it was just air getting pushed through, but it doesn't ever seem to stop. As in, there isn't ever enough water to fill in all of the places bubbles are. I just wrote it off as VW's being a pain to bleed the air out and every time you take the cap off, it sprays some water out because of the change is pressure.
  7. #7
    Haul'n the Family fastforward has a reputation beyond repute fastforward has a reputation beyond repute fastforward has a reputation beyond repute fastforward has a reputation beyond repute fastforward has a reputation beyond repute fastforward has a reputation beyond repute fastforward has a reputation beyond repute fastforward has a reputation beyond repute fastforward has a reputation beyond repute fastforward has a reputation beyond repute fastforward has a reputation beyond repute fastforward's Avatar
    Join Date
    Dec 2001
    Location
    Riverview
    Posts
    2,371
    Feedback Score
    If you have a blown headgasket I would think you would have loss of compression in one or more cylinders. A blown gasket doesn't always mean you are going to have coolant/oil cross contamination.
    Get a compressioon checker and a Haynes manual (for the compression specs.)
    With the checker screwed into the spark plug hole you can turn the motor over (but not start it) and have some else watch the gauge.
    I think you can borrow a compression check gauge at Discount Auto or the other stores. Basically you buy it, use it, and they give you your money back when you bring it back.
  8. #8
    Join Date
    Jan 2009
    Posts
    4,177
    Feedback Score
    yeah, but a compression tester isn't going to narrow it down to the headgasket... that will also point to vavles and seals and all that fun too..
    a leak down test is the only way to test for it, at least accurately....
  9. #9
    Join Date
    Dec 2001
    Location
    Riverview
    Posts
    2,371
    Feedback Score
    Quote Originally Posted by Empire View Post
    Sure, bad compression won't narrow it down to just being a head gasket, but it will start to eliminate the variables. Combine a leak down witha compression test and really narrow it down, But, if you really want to know if it's the head gasket thats causing your issues then you'll just have to pull the head.
  10. #10
    Race Photographer Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up!
    Join Date
    Nov 2000
    Posts
    43,533
    Feedback Score
    6 (100%)
    Theres all kinds of things that happen when you have a blown headgasket. This is another test you should try before pulling the head, but it does seem like you have a blownhead gasket.
    UVIEW 560000 Diesel & Gas Combustion Leak Tester Kit - eBay (item 200276192949 end time Aug-12-09 12:30:48 PDT)
    you can pick these up at parts stores locally.
  11. #11
    Join Date
    Nov 2000
    Posts
    43,533
    Feedback Score
    6 (100%)
    and a compression test can tell you if you have a blown headgasket, but usually only in severe cases. The leakdown test acutally helps you narrow it down since you can determine where the air is escaping from.
  12. #12
    pfft..... Garrett has a reputation beyond repute Garrett has a reputation beyond repute Garrett has a reputation beyond repute Garrett has a reputation beyond repute Garrett has a reputation beyond repute Garrett has a reputation beyond repute Garrett has a reputation beyond repute Garrett has a reputation beyond repute Garrett has a reputation beyond repute Garrett has a reputation beyond repute Garrett has a reputation beyond repute Garrett's Avatar
    Join Date
    Jan 2001
    Location
    In a van down by the river
    Posts
    5,493
    Feedback Score
    since you dont have any fluid loss or mixing of fluids it sounds more like a faulty/bad coolant temperature sensor
    coolant temp sensors are known to go bad in VW's
  13. #13
    Join Date
    May 2005
    Location
    Posts
    6,426
    Blog Entries
    Feedback Score
    19 (100%)
    You might also burp out the air from the system.-Bob
    Garret,
    I use this term because a buddy with a VW Turbo S
    also uses the term, and I presume it would be understood
    by most people.
  14. #14
    Join Date
    Jan 2001
    Location
    Posts
    5,493
    Feedback Score
    Quote Originally Posted by senor honda View Post
    you cant actually burp a VW cooling system as they dont have radiator caps.
    All you can really do is fill the resivoir and then if the system drains that keep filling it till the fluid doesnt go below the fill line.
  15. #15
    Hey its that guy!! Thatguysstuff has a reputation beyond repute Thatguysstuff has a reputation beyond repute Thatguysstuff has a reputation beyond repute Thatguysstuff has a reputation beyond repute Thatguysstuff has a reputation beyond repute Thatguysstuff has a reputation beyond repute Thatguysstuff has a reputation beyond repute Thatguysstuff has a reputation beyond repute Thatguysstuff has a reputation beyond repute Thatguysstuff has a reputation beyond repute Thatguysstuff has a reputation beyond repute Thatguysstuff's Avatar
    Join Date
    Apr 2006
    Location
    Lakeland
    Posts
    8,764
    Feedback Score
    65 (99%)
    Hmmm... but you said it stops blowing hot... when it over heats..?? sounds like a bad thermo stat.. . even a new one can fail.. i have had it happen on my type R...
    My headgasket went out on my type R and i had no smoke, no water in the oil... mine was leaking pressure from the cylinders into my water jacket.. make me push all my water out the over flow tank..
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
