+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 28
  1. #1
    is sorta fast Bowtie has a reputation beyond repute Bowtie has a reputation beyond repute Bowtie has a reputation beyond repute Bowtie has a reputation beyond repute Bowtie has a reputation beyond repute Bowtie has a reputation beyond repute Bowtie has a reputation beyond repute Bowtie has a reputation beyond repute Bowtie has a reputation beyond repute Bowtie has a reputation beyond repute Bowtie has a reputation beyond repute
    Join Date
    Dec 2005
    Location
    Wesley Chapel
    Posts
    669
    Feedback Score
    2 (100%)
    best coolant mixture that everyone uses?
    whats everyones opinion its time to change coolant in my car.. or maybe can hopefully solve this problem. I just had the oil changed on the burban worked flawlessly for 2 days until i notice the temp gauge just slowly goes up to 260 and comes back down to normal in a timeframe of about 30 seconds.. it only happens when im at a light then it stays put and work its way up to about 210 then when i go it hits 260 then 30 seconds later back down to about 180... i changed the sending unit on it.. i was thinking of thermostat and the coolant next then the water pump because that does seems like a ghost you can chase...
    Project Snowsled
    Powered by LT1
    Monroe/ Belltech Suspension
    2.5" True Duals with Flowmaster 40's
    Built 700R4 By: Tim Moye Transmission
    CSR Electric Waterpump
  2. #2
    Banned cha0tic has a reputation beyond repute cha0tic has a reputation beyond repute cha0tic has a reputation beyond repute cha0tic has a reputation beyond repute cha0tic has a reputation beyond repute cha0tic has a reputation beyond repute cha0tic has a reputation beyond repute cha0tic has a reputation beyond repute cha0tic has a reputation beyond repute cha0tic has a reputation beyond repute cha0tic has a reputation beyond repute
    Join Date
    Jan 2007
    Posts
    4,226
    Feedback Score
    3 (100%)
    i'm cheap son. i use the water hose
  3. #3
    Join Date
    Dec 2005
    Location
    Wesley Chapel
    Posts
    669
    Feedback Score
    2 (100%)
    yea i know i was cheap too but look where that got me to a problem
    Project Snowsled
    Powered by LT1
  4. #4
    Join Date
    Jan 2007
    Posts
    4,226
    Feedback Score
    3 (100%)
    supposedly water cools better then coolant, but coolant doesn't rust like water
  5. #5
    Still Addicted to Boost J-Dizzle has  hit bottom,  and can only go up! J-Dizzle has  hit bottom,  and can only go up! J-Dizzle has  hit bottom,  and can only go up! J-Dizzle has  hit bottom,  and can only go up! J-Dizzle has  hit bottom,  and can only go up! J-Dizzle has  hit bottom,  and can only go up! J-Dizzle has  hit bottom,  and can only go up! J-Dizzle has  hit bottom,  and can only go up! J-Dizzle has  hit bottom,  and can only go up! J-Dizzle has  hit bottom,  and can only go up! J-Dizzle has  hit bottom,  and can only go up! J-Dizzle's Avatar
    Join Date
    Jan 2003
    Location
    Land O' Lakes
    Posts
    9,474
    Feedback Score
    8 (100%)
    could be a temp sensor. i only use Dealer coolants i dont use that green shit,its bad for your water pump housing.
  6. #6
    Join Date
    Jan 2003
    Location
    Land O' Lakes
    Posts
    9,474
    Feedback Score
    8 (100%)
    Quote Originally Posted by Elbow Bender View Post
    yes but coolant protects things water can't.
  7. #7
    Join Date
    Jan 2007
    Posts
    4,226
    Feedback Score
    3 (100%)
    idk never had problems with using water in a few cars
  8. #8
    Join Date
    Dec 2005
    Location
    Wesley Chapel
    Posts
    669
    Feedback Score
    2 (100%)
    ive been reading that distilled water and water wetter works really good.. but i want to maintain my 180 i had before..
    Project Snowsled
    Powered by LT1
  9. #9
    Zero By Default jw34689 has a reputation beyond repute jw34689 has a reputation beyond repute jw34689 has a reputation beyond repute jw34689 has a reputation beyond repute jw34689 has a reputation beyond repute jw34689 has a reputation beyond repute jw34689 has a reputation beyond repute jw34689 has a reputation beyond repute jw34689 has a reputation beyond repute jw34689 has a reputation beyond repute jw34689 has a reputation beyond repute jw34689's Avatar
    Join Date
    May 2005
    Location
    tarpon springs
    Posts
    1,444
    Feedback Score
    16 (100%)
    the premix 50/50
    2. When questioned by a friend's girlfriend, you need not and should not provide any information as to his whereabouts. You are even permitted to deny his very existence.
    37. Before allowing a drunken friend to cheat on his girl, you must attempt one intervention. If he can get up on his feet, look you in the eye, and deliver a "fuck off" then you are absolved from all responsibility.
  10. #10
    Troll extraordinaire bishoppac8 has a reputation beyond repute bishoppac8 has a reputation beyond repute bishoppac8 has a reputation beyond repute bishoppac8 has a reputation beyond repute bishoppac8 has a reputation beyond repute bishoppac8 has a reputation beyond repute bishoppac8 has a reputation beyond repute bishoppac8 has a reputation beyond repute bishoppac8 has a reputation beyond repute bishoppac8 has a reputation beyond repute bishoppac8 has a reputation beyond repute bishoppac8's Avatar
    Join Date
    Feb 2007
    Location
    tarpon springs
    Posts
    2,126
    Feedback Score
    16 (100%)
    sounds like what my cars do right after i put coolant in them and dont bleed the system ...
  11. #11
    Wide Open and Sideways! importguy1208 has a reputation beyond repute importguy1208 has a reputation beyond repute importguy1208 has a reputation beyond repute importguy1208 has a reputation beyond repute importguy1208 has a reputation beyond repute importguy1208 has a reputation beyond repute importguy1208 has a reputation beyond repute importguy1208 has a reputation beyond repute importguy1208 has a reputation beyond repute importguy1208 has a reputation beyond repute importguy1208 has a reputation beyond repute
    Join Date
    Sep 2005
    Location
    Central Florida
    Posts
    2,279
    Feedback Score
    3 (100%)
    If you run distilled water you eliminate a lot of the problems of tap water. Throw some Redline water wetter in the mix and you'll have the better benefits of coolant with the better cooling ability of water.
    EDIT: I was typing this while bowtie posted so basically I've read the same thing and have used it in my motorcycles, trucks, and cars with NO problems. NO rust, calcium build-up, or goofy temp problems.
    Central Florida Auto Works!!! Paint & Body Work, Fiberglass/Carbon Fiber/Kevlar, Mechanical/Fabrication/Welding Phone: (352) 274-3446 AIM: ImportGuy1208
  12. #12
    Join Date
    Dec 2005
    Location
    Wesley Chapel
    Posts
    669
    Feedback Score
    2 (100%)
    but how do i mix that appropriately^
    Project Snowsled
    Powered by LT1
  13. #13
    pfft..... Garrett has a reputation beyond repute Garrett has a reputation beyond repute Garrett has a reputation beyond repute Garrett has a reputation beyond repute Garrett has a reputation beyond repute Garrett has a reputation beyond repute Garrett has a reputation beyond repute Garrett has a reputation beyond repute Garrett has a reputation beyond repute Garrett has a reputation beyond repute Garrett has a reputation beyond repute Garrett's Avatar
    Join Date
    Jan 2001
    Location
    In a van down by the river
    Posts
    5,493
    Feedback Score
    Quote Originally Posted by Bowtie View Post
    its not hard i usually just put about a gallon or so of distilled start the car then pour in the water wetter (one bottle will usually treat up to 5 or 10 gallons) then top off with more distilled then leave the car running for about 10 min to allow water to mix well..
  14. #14
    Race Photographer Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up!
    Join Date
    Nov 2000
    Posts
    43,533
    Feedback Score
    6 (100%)
    sounds like t-stat to me
  15. #15
    Why so Miata? Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian has a reputation beyond repute Orion ZyGarian's Avatar
    Join Date
    May 2004
    Location
    Venice, FL
    Posts
    8,688
    Feedback Score
    As far as the mixture, I run about 70/30 water/coolant myself. Coolant is only necessary in Florida for corrosion inhibiting and water pump lubrication.
    ASE: Brakes
    I can get you Pampered Chef stuff. Just sayin'
    RIP JZDeLorean and Tyler
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
