+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
  1. #1
    Ecotec y0! Scott90 has a reputation beyond repute Scott90 has a reputation beyond repute Scott90 has a reputation beyond repute Scott90 has a reputation beyond repute Scott90 has a reputation beyond repute Scott90 has a reputation beyond repute Scott90 has a reputation beyond repute Scott90 has a reputation beyond repute Scott90 has a reputation beyond repute Scott90 has a reputation beyond repute Scott90 has a reputation beyond repute Scott90's Avatar
    Join Date
    May 2006
    Location
    USAF
    Posts
    7,434
    Feedback Score
    1 (100%)
    where can I get a motor flush done?
    Its for my moms car, a 01 sunfire.
    lots of sludge in this engine, ticking like crazy from what we think is just valves and shit... i pretty much need the head removed and fully cleaned, and the oil pan puilled and cleaned. typically a motor flush, what shops can do it, where can it be done, how much about.... thanks
    i can do it myself but i just work a lot and rather pay to have it done for her quickly.
    "Decide what you want, decide what you are willing to exchange for it. Establish your priorities and get to work."
  2. #2
    Banned cha0tic has a reputation beyond repute cha0tic has a reputation beyond repute cha0tic has a reputation beyond repute cha0tic has a reputation beyond repute cha0tic has a reputation beyond repute cha0tic has a reputation beyond repute cha0tic has a reputation beyond repute cha0tic has a reputation beyond repute cha0tic has a reputation beyond repute cha0tic has a reputation beyond repute cha0tic has a reputation beyond repute
    Join Date
    Jan 2007
    Posts
    4,226
    Feedback Score
    3 (100%)
    any mechanic shop? look in phonebook and call around to get the best estimates
  3. #3
    Obama made me Republican thereturnofdark has a reputation beyond repute thereturnofdark has a reputation beyond repute thereturnofdark has a reputation beyond repute thereturnofdark has a reputation beyond repute thereturnofdark has a reputation beyond repute thereturnofdark has a reputation beyond repute thereturnofdark has a reputation beyond repute thereturnofdark has a reputation beyond repute thereturnofdark has a reputation beyond repute thereturnofdark has a reputation beyond repute thereturnofdark has a reputation beyond repute thereturnofdark's Avatar
    Join Date
    Mar 2004
    Location
    tampa
    Posts
    11,775
    Feedback Score
    15 (100%)
    Seems like you're looking for a engine rebuild my friend.....if you're taking the head off and dismantling valves and such i'd imagine you'd want to replace head gasket, other gaskets/seals, etc. at the same time....... just suggestions.
  4. #4
    Daewoo Frankenstein BosnianLanos has a reputation beyond repute BosnianLanos has a reputation beyond repute BosnianLanos has a reputation beyond repute BosnianLanos has a reputation beyond repute BosnianLanos has a reputation beyond repute BosnianLanos has a reputation beyond repute BosnianLanos has a reputation beyond repute BosnianLanos has a reputation beyond repute BosnianLanos has a reputation beyond repute BosnianLanos has a reputation beyond repute BosnianLanos has a reputation beyond repute BosnianLanos's Avatar
    Join Date
    May 2007
    Posts
    253
    Feedback Score
    4 (100%)
    An engine flush to remove sludge is a generally bad idea. The chemicals needed to do this are VERY caustic and will damage gaskets and seals. Not to mention that sludge can harden like concrete, so if you don't get most or all of the particles out, they can cause engine and valve train damage. My sister's 97 Civic LX had a horrible case of engine sludge that we found when we changed the valve cover gasket. We called our family mechanic and he said that unless we want to get engine knock within a week or two of the flush, the best bet was to lightly clean off that which you can see with a rag, and then decrease oil change intervals to 2000 miles to help melt some of the sludge. This is what we've been doing since then. Even at 2000 miles the oil looks THICK. I'll take the valve cover off later this summer to see the progress.
    Just my .02 cents.
  5. #5
    Just for decoration JonLGT has a reputation beyond repute JonLGT has a reputation beyond repute JonLGT has a reputation beyond repute JonLGT has a reputation beyond repute JonLGT has a reputation beyond repute JonLGT has a reputation beyond repute JonLGT has a reputation beyond repute JonLGT has a reputation beyond repute JonLGT has a reputation beyond repute JonLGT has a reputation beyond repute JonLGT has a reputation beyond repute JonLGT's Avatar
    Join Date
    Dec 2003
    Location
    LWR
    Posts
    11,159
    Feedback Score
    10 (100%)
    Grab your hose!
  6. #6
    Race Photographer Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up! Mars_302 has  hit bottom,  and can only go up!
    Join Date
    Nov 2000
    Posts
    43,533
    Feedback Score
    6 (100%)
    leave it alone and just keep up with your oil changes
  7. #7
    Join Date
    May 2006
    Location
    USAF
    Posts
    7,434
    Feedback Score
    1 (100%)
    ... i didnt ask whether or not i should do it? either way its getting done... whether i do it or a shop does it, its not a hard task, ive done it before to my sisters cars.. hmmm coincidence women and not changing their damn oil on time haha
  8. #8
    Join Date
    Dec 2003
    Location
    LWR
    Posts
    11,159
    Feedback Score
    10 (100%)
    Quote Originally Posted by Scott90 View Post
    If you have done it before and are confident it works why are you asking us?
  9. #9
    Registered User Miata GT has a reputation beyond repute Miata GT has a reputation beyond repute Miata GT has a reputation beyond repute Miata GT has a reputation beyond repute Miata GT has a reputation beyond repute Miata GT has a reputation beyond repute Miata GT has a reputation beyond repute Miata GT has a reputation beyond repute Miata GT has a reputation beyond repute Miata GT has a reputation beyond repute Miata GT has a reputation beyond repute Miata GT's Avatar
    Join Date
    Jul 2003
    Location
    Tampa
    Posts
    82
    Feedback Score
    There is something the Miata boys do called a 2TWISTY engine flush (name from the person on Miata.net who came up with the concept). I have performed it on several cars with great success.
    Here is a link: East-Side Miatas of Tampa Bay
    Obviously the ratio will stay the same but the amounts would change based on how much oil her car will hold.
  10. #10
    Join Date
    May 2007
    Posts
    253
    Feedback Score
    4 (100%)
    I've heard that or variations of that done before. It'll work for run-of-the-mill jobs, but you'll need to do that 20 times to clean the amount of sludge this guy is talking about.
    But yeah, if you're set on it, no worries. Any shop should be able to do it for you. Just make sure you get quotes for a rebuild too.
    I'm not trying to be a dick, but written literature states that engine/transmission flushes, especially on new cars with tighter tolerances, can cause big problems.
  11. #11
    I <3 USDM Saleen06 has a reputation beyond repute Saleen06 has a reputation beyond repute Saleen06 has a reputation beyond repute Saleen06 has a reputation beyond repute Saleen06 has a reputation beyond repute Saleen06 has a reputation beyond repute Saleen06 has a reputation beyond repute Saleen06 has a reputation beyond repute Saleen06 has a reputation beyond repute Saleen06 has a reputation beyond repute Saleen06 has a reputation beyond repute Saleen06's Avatar
    Join Date
    Mar 2006
    Location
    St pete
    Posts
    726
    Feedback Score
    1 (100%)
    one word, seafoam....
  12. #12
    it's Mark - Zero - Nine markzeronine has a reputation beyond repute markzeronine has a reputation beyond repute markzeronine has a reputation beyond repute markzeronine has a reputation beyond repute markzeronine has a reputation beyond repute markzeronine has a reputation beyond repute markzeronine has a reputation beyond repute markzeronine has a reputation beyond repute markzeronine has a reputation beyond repute markzeronine has a reputation beyond repute markzeronine has a reputation beyond repute markzeronine's Avatar
    Join Date
    Oct 2002
    Location
    Citrus Park
    Posts
    12,289
    Feedback Score
    18 (100%)
    flush the motor down the drain
    This is a stick up, don't make it murder.
  13. #13
    The Cyber Brain Superluminal has a reputation beyond repute Superluminal has a reputation beyond repute Superluminal has a reputation beyond repute Superluminal has a reputation beyond repute Superluminal has a reputation beyond repute Superluminal has a reputation beyond repute Superluminal has a reputation beyond repute Superluminal has a reputation beyond repute Superluminal has a reputation beyond repute Superluminal has a reputation beyond repute Superluminal has a reputation beyond repute Superluminal's Avatar
    Join Date
    Feb 2007
    Location
    Tampa
    Posts
    1,958
    Feedback Score
    5 (100%)
    Quote Originally Posted by markzeronine View Post
    I like this suggestion.
  14. #14
    Join Date
    Jul 2003
    Location
    Tampa
    Posts
    82
    Feedback Score
    I use seafoam for cleaning the intake. You can use it for the crankcase but ATF works as well.
  15. #15
    Join Date
    Nov 2000
    Posts
    43,533
    Feedback Score
    6 (100%)
    im an expert and im telling you to leave it alone. If you feel the need to rip the motor apart just go buy another motor, it will be cheaper and easier in the short and long run. If its really sludged up and you decide to run some 5 minute motor flush thru it, its just going to clog up your oil pump and you aer going to be messing up a motor. Like I said, just leave it alone and keep up with your oil changes and let it come out naturally and slowly.
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
