Thread: Parking on a steep driveway?
02-20-2007 12:01 AM #1
I'm not that knowledgeable when it comes to cars. Is there a recommended way to park a car if you're on a steep driveway? Steep would mean that the ground level at the garage is higher than the ground level of the road.
I was told that I should park the car with the front facing the road, and that it was bad to park it with the back facing the road. Any truth to this?
I've also asked this question in another forum before, and I was told that "turn the wheels to one side, and let the car rock back on the parking brake before you put it in park... basically, i put the parking brake on, put it in neutral, take my foot off the brake and let the car rock back and stop, and then put it in park. that way, you don't have a lot of load on the transmission interlock when you try to take it out of park next time."
What do you think?
Thanks!
02-20-2007 12:06 AM #2E & I Certified
- Join Date
- Feb 2003
- Location
- Under a Mustang.....
- Posts
- 11,095
- Feedback Score
- 12 (100%)
park in the garage
02-20-2007 12:11 AM #3Registered User
- Join Date
- Sep 2003
- Location
- Valrico, FL
- Posts
- 3,937
- Feedback Score
- 3 (100%)
I don't see why it would be bad to park with the back facing the road... You should let it rest on the parking brake beofre putting it in park.
02-20-2007 01:53 AM #4Registered User
- Join Date
- Feb 2004
- Location
- port richey
- Posts
- 1,048
- Feedback Score
- 0
i don't even use the parking brake on my auto cars. the stick car and truck i have to use it other wise they will roll into the street. i pull in 99% of the time. i've lived in this house for 7 years and i haven't had a problem.
02-20-2007 04:22 AM #5
i would suggest parking it the way your driving test study packet told you to park it...since you know, it was part of the learning material for you to get that thing that says its ok for you to drive the things your having a hard time parking.
put blocks behind your tires if you are that scared of it rolling away.El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
02-20-2007 08:48 AM #6
I'm not scared of the car rolling off. From what I was told, prolong parking on a steep area will contribute to added stress on the car. If I park the car with the rear facing the street, it's supposed to mess up the transmission. I don't know why, though.
The bottom line is I'm trying to get the actual answers as to what stresses affects a car if its park with its front or back towards the street. Then, weigh in the factors to see if there really is a difference.
02-20-2007 02:30 PM #7
Driving definitions: Understeer is when you hit the wall with the front of the car and Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and Torque is how far you take the wall with you.
02-20-2007 07:01 PM #8Registered User
- Join Date
- Feb 2004
- Location
- port richey
- Posts
- 1,048
- Feedback Score
- 0
i think the motor slowly turns over. i know the clutch doesn't slip since i have no problem spinning the tires in 3rd. the javelin will stay, but with a little pressure it will roll back some. i never wanted to take the chance of coming out one morning and finding it in the street.
i parked the ram 2500 for a while without a parking brake when the PB cable broke.
but that has a granny gear, 15mph top speed in that gear. in 2nd it will do the same as the javelin on my driveway.
02-21-2007 02:10 AM #9
Why would the motor turn over? Theres no fuel being applied to it. Even if it was to turn over. But a good tranny/clutch wont allow that to happen. Ive never owned a auto and always park my cars in gear.
02-21-2007 11:38 AM #10
putting it in park without the parking brake puts all the weight of the car onto the transmission and in turn the engine mounts which if you have ever watch the engine bay when the weight hits it, its a really bad idea.
Ebrake FTW.
02-21-2007 12:20 PM #11Field Rep
- Join Date
- Jun 2005
- Location
- cali
- Posts
- 2,239
- Feedback Score
- 12 (100%)
your fine if u just leave it in gear..no need for ebreak..
ive had a ebreak snap on me and just left in gear for years with no issue
dont worry bout it so much just always turn your wheelsyou see its not the blood you spill that gets you what you want, its the blood you share. your family, your friendships, your community. these are the most valuable things a man could have
02-21-2007 10:57 PM #12
just put the ebrake on, i'm sure they're saying that the fluids will drain to one side and starve the pump or whatever, but if you have plenty of fluids in there you should be fine, i'm sure your vehicle manufacturer took into account that one day you may park on a hill
and if its an open driveway, if you turn the wheels all it'll do is run through your yard into the streat, the point of it is if you park on a curb, you turn your wheels away from it so if it rolls away your tires just roll right into the curb and no problems
02-21-2007 11:06 PM #13
02-21-2007 11:11 PM #14
i suppose if there was enough weight you could turn the engine, there is no lock on it when your in gear, how else do you then you could pop start it
come on people, think here
its possible, but shouldn't just parked
02-21-2007 11:12 PM #15
If your clutch cant hold the car in gear it will pop out. It happens to my DD. I have a bad clutch in it. but the tranny is fine, if i leave it in gear it will slowly roll back some times since the clutch isnt able to hold the gear in place like its supposted too.
Thread Information
Users Browsing this Thread
LinkBack URL
About LinkBacks
1989 Ford Mustang GT
1990 Ford Mustang LX
2002 Ford P71
2005 Dodge Ram Hemi 4x4 1500 Quad Cab
