SPDT relays
ok guys, i need some help, the numbers are different on the relay i got, its only a 4 prong, but it should work right?
this is what is in the write-up
and i've got
30-h terminal for lights or horns
87-b terminal from power source
86-s terminal from switch
85-m terminal for relay ground wire
so whats what here?
i'm lost, and i am using the relay joebobclark recommended
Relay # 1
85 - Cut green and red wire coming from controls on steering wheel and attach to signal side.
86 - Ground.
87 - Cut green and black wire coming from controls on steering wheel and attach to signal side.
87a - Not used.
30 - To terminal 85 on relay # 2.
Relay # 2
85 - To terminal 30 in relay # 1.
86 - Ground
87 - 12v ignition (preferably 10 gauge wire ran directly to ignition harness).
87a - Not used
30 - Cut starter wire in ignition harness and connect to starter side.
86 - Ground.
87a - Not used.
Relay # 2
86 - Ground
87a - Not used
and i've got
so whats what here?
every place you mentioned stocks them, EVEN WALMART!
Best buy doesnt though....
If you want i can grab one for you for a 1dollar transport-shipping-fee-to-your-front-door...
and i've got
so whats what here?
and i've got
so whats what here?
some relays have the prong numbers actually printed on it, so you wont get confused.
85 and 86 are interchangeable unless you have a polarized relay....which you would only get fron online specialty sites..... those 2 tabs are just the coil side of the relay, put current through the relay in either direction and it trips the contacts.
87 and 87a are the normally open and normally closed side of the contacts and 30 is the common side of the contacts. as long as the device is powered by running through the contacts then it doesn't matter if you hook power to 87 and then 30 to the device or hook power to 30 and 87 to the device the result is the same......when the relay is energized the contacts flip and give power to your circuit.
hook your switch to one side of the coil and the item you want to power to one side of the contacts. the rest is power and ground hookups
If you got 4 post ones, they are the wrong ones (SPST). You need the 5 post ones (SPDT). After Googleing the part number I posted it looks like it is the wrong one (SORRY). Just go back and exchange them for the 5 post ones, they should have those as well.
I have a five post relay in front of me.
Terminals are labeled:
30
85
86
87
87a
It came from a japanese car.
A dodge Neon has the same relay used for
horn and A/C clutch. The numbers on the relay are:
56006709
50732
a third number is "melted" into the plastic , maybe a batch number.
You can get this relay at a junkyard......-Bob
So if one terminal is not used, why do you need a SPDT 5 pin relay?-Bob
30
85
86
87
87a
56006709
50732
No matter how the relay is labeled with numbers it should have a diagram on it and you can wire it up from that. The diagrams will pretty much have a coil on them that throws a high amp switch, you just need to coordinate which number goes with which wire you have, since it sounds like the numbers change (I'm used to 30, 87 etc) I usually go by the diagrams anyway, so if you need to refer to this:
As long as you are using the correct fuse and gauge wire for the amps, I don't see why you couldn't use a single throw relay and splice the wire that goes to the load into 2 sepererate wires?
"They must really feed each other to the lions down there........"
