Forums Register TRHelp TRGarage TRader Ratings Classifieds Search Today's Posts Mark Forums Read Calendar
iTrader Mainpage
Browse All Members
FAQ Gallery Weather Log Out
Go Back   Tampa Racing > General > General Car Chat
Old 01-04-2007, 04:14 PM   #16 (permalink)
Car:
rija is an unknown quantity at this point: 10
Quote:
Originally Posted by 2kSnakeater View Post
$32.400.00 kit for you "bimmer"
Before sending the car to istanbul, the kit price was 9600 euro,
when i arrived there after a 5 day trip, Mert Dastan, DA MOTORSPORT team chief, told me that i must make some chassis modifications unless he could not do the tests because of the torque. And he added that I also need to change the flywheel to a lighter one, cost about 900 euro and so on... here is the e-mail:
- You need new valves. Also your valve springs must be changed with modified ones. Your current valve springs cannot open and close at 2.2 bar of boost pressure. 9 of the valves are worn and when they are seated they do not seat properly. Also most of the valve steams are worn. We will buy new valves and also heavy duty valve springs. Your current valve springs must be changed. Racing valve springs, upper and lower titanium retainers will be installed. 1640 euro including labor of the head and installation.
- Chasis must be modified. You were in my car and this is no joke. If we do not modify the rear end of the M3 we will damage it during software tuning. We must do it. The first part that will fail is the rear subframe. The final drive carrier will flex and damage the transmission and propeller shaft. We will damage these parts during software tuning. 1.420 Euro for chasis and final drive carrier mods.
- We need a X brace 245 Euro, Front tower brace 420 Euro and rear tower brace 540 Euro. Without these 3 items we cannot test the car. This is not a child’s game. Chasis flexes under 1000 nm of torque if you do not install these parts.
- 2 tires 255-40-17 Bridgestone S03 480 Euro (here we have expensive tires)
- you need a longer final drive. We cannot install the gears if you send them. There is no man here that can do the gear installation. With this short final drive the car cannot make as much boost pressure as it can with a standard final drive. We can find a second hand final drive here. You need a longer final drive at least the standard gear ratio of 3:23
- You need the clutch which we use. This clucth and pressure plate will not hold under 1000 nM of torque and needs to be replaced. 1260 Euro
- You also need a flywheel, your flywheel is worn and need to be replaced with a stronger one. Standard M3 flywheels get damaged under 2.2 bar. 960 Euro. These items MUST be changed. Without these items we cannot modify your car. Please talk to your cousin and write me an email. If one of these items fail we cannot finish the 1000 hp project. You have been in my car and saw how it was. We have serious boost pressures. Your M3 will run at 2.2 bar and rev 8300 rpm.
Best regards Mert DASTAN -- DA Team Chief S50B32 + Garrett GT42 = 1.000+ hp --
Chassis mods only consist on front and rear tower brace, and X brace... They didn't modify the final drive carrier.
I have no modified flywheel...
So the final price was 19600 euros, not 32000 usd...
I also paid 4700 euro to the customs before leaving because the car stayed too long in turkey!
rija is offline
Old 01-04-2007, 04:19 PM   #17 (permalink)
Hatches are the jam!
Car: Mighty Max
California
Ronald Mcdonald has a reputation beyond repute: 660555310
Is that used or new? I think a new super charger kit costs in the range of $8k-$10k compare that to an F-body kit ($2k-$4k) thats fucking nuts.
That was for a brand new kit.
Don't remember where I saw it, but I remember it. ( I know that means nothing without proof, so I shall end my case, haha )
Ronald Mcdonald is offline
Old 01-04-2007, 04:28 PM   #18 (permalink)
Pastafarian FOR LIFE!!!!!
Car: 2004 Ferrari Enzo
Under your bed
2kSnakeater has much to be proud of: 1460061
so 19600 Euro + 4700 Euro = 32226.66 U.S. dollars
2kSnakeater is offline
Old 01-04-2007, 04:29 PM   #19 (permalink)
realer than most
Car: blue
lakeland
SkwervE has a reputation beyond repute: 2147483647
ooold on ooold on ima jak diz thredz fo a min nucca.. i had been done sent ma dam bimma to diz place on da otha side of da globe fo a lil minute to get ma dam turro charga put on and diz place had done been jaked ma monay so i had said nigga you a hax0r gimmie ma money and den he had said man you a bussa get dat shit out hurr... and now i be sittin at da crib thankin bout what to do to diz foo.. plz TR help a po nigga out
SkwervE is offline
Old 01-04-2007, 04:32 PM   #20 (permalink)
Under your bed
where are you located? and why in hell would you send your car to Turkey? why didnt you just get an M5 instead of spending a butt load of money for a car that your going to have to rebuild every 40,000 Km? There is a line between nice sportcar that you can drive in the city and a race car that would be so un-safe and so powerfull that cannot be driven in the city. You crossed that line a long time ago.
Old 01-04-2007, 04:52 PM   #21 (permalink)
Car: S2k.Mustang.Sv650s
Indianapolis/Tampa
DannyObrien has a reputation beyond repute: 149969051
I think hes not from America.
DannyObrien is offline
Old 01-04-2007, 05:04 PM   #22 (permalink)
King of Ricers
Car: =
Tampa
Notladstyle has a reputation beyond repute: 229487081
that email sounds like one of the spam emails I get 40,000 times a day.
Its like hes convinicing hte guy that hes reall with BS stats and restating hte same thing over n over again.
Notladstyle is offline
Sponsored Links
