#22 (permalink) | |
yep yep
Car: W208 x 2
West Palm Beach, Florida
: 43627282 |
Re: Had rims Powder Coated?
Quote:
Here is the story. First to get them stripped, if they are aluminum like my Carlssons were, you need to get them bead blasted instead of sand blasted because sand blast will pit the wheels. This part was super expensive, like almost $200 for all four wheels. Then the pc part was cheap. I had all four done for something like $80. It sucked though because shortly after they began to peel. I ended up selling them. If you powdercoat, get ready to get some new valve stems because the heat process will destroy your. I had to pay to get tires mounted to find out they were leaking, only to pay to get them unmounted to put valve stems on and mount them again. It was all a huge pain in the ass, and I would never do it again. The pc only lasted for like a week before they peeled. It was also costly. |
#23 (permalink) | |
drives euro trash
Car: 2004.5 Passat Oberwagon, 2007 Rabbit
Brandon, FL
: 79454120 |
Re: Re: Had rims Powder Coated?
Quote:
Taking off the valve stems is just common sense. You cannot properly prep a wheel without taking them out. Plus anyone should know baking rubber in an oven isn't exactly the smartest idea. Who did the work? I think we all would like to know where NOT to go. |
#24 (permalink) | |
Can you spot me 20 cars?
Car: 04 S2K FTW
In my car
: 88494165 |
Re: Re: Re: Had rims Powder Coated?
Quote:
#25 (permalink) | |
yep yep
Car: W208 x 2
: 43627282 |
Quote:
#26 (permalink) |
Car:
st. pete
: 39286838 |
You can take care of the prep work by useing aircraft paint remover. Plenty of people have used that to strip their rims with no ill affects. ts very toxic so use in a well ventilated place. Have the tires, valve stems, and weights off the rim before working on them. It should take but a few minutes per wheel. Brush on, wait a few minutes, then wiped off and your done.
#27 (permalink) | |
Car:
U.S.A. and Proud of it!
: 490 |
Quote:
#29 (permalink) |
is retired...
Car: 1989 ef hb
Ridgemanor
: 2147483647 |
There's a tamparacing local(brooksville) member that powdercoats...if he can fit one of your rims in the oven Im sure he could do better than 75 a wheel. PM him his name is Tranceologist.
| Sponsored Links |
