+ Reply to Thread
Results 1 to 2 of 2
  1. #1
    Registered User FICINJECTORS is an unknown quantity at this point
    Join Date
    May 2011
    Posts
    42
    Feedback Score
    Injector Servicing and Restoration
    THE SERVICE INCLUDES:
    1) Injectors are externally cleaned, visual inspected
    2) We test injectors for resistance, shorts, and current draw.
    3) We perform leak test, spray pattern, and flow rate testing on one of our 3 ASNU flow benchs. All data is recorded and sent to you.
    4) Remove filter baskets, o-rings, and pintle caps. Metal injectors are bead blasted to remove old paint and rust from the injector body.
    5) The injectors are placed in a heated ultrasonic bath to insure that the injector is free of dirt and contamenants that could hinder the rest of the process.
    6) The injectors are now put into another ultrasonic system while they are pulsed allowing the ultrasonic energy to dislodge any particles and build-up inside the injectors.
    7) The injectors are now back flowed to remove all debris, etc.
    The injectors are now returned to the flow bench for retesting of all functions. The data from this test is returned to you in detail with your injectors.
    9) The injectors are now refinished with high temp paint. the stainless steel injectors are polished to a high finish.
    10) One of our techs. now reassembles the injector, using all new parts.
    11) The injectors are then vac sealed and packaged for shipment along with the old parts.
    Prices are
    $15 per injector for top feed
    $20 per injector for side feed.
    Usual turnaround time is around 1 week.
    ~Rich
  2. #2
    Join Date
    May 2011
    Posts
    42
    Feedback Score
    Average turnaround is now down to 3 days or LESS.
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
