+ Reply to Thread
Results 1 to 5 of 5
Thread: Injector Videos!!
05-03-2011 10:13 AM #1Registered User
- Join Date
- May 2011
- Posts
- 42
- Feedback Score
- 0
Injector Videos!!
WE RECEIVE SO MANY E MAILS REQUESTING WHERE THESE VIDEOS ARE SO I DECIDED TO PUT THEM ALL ON ONE THREAD. These are all very popular injectors for many many vehicles.
SPRAY PATTERN COMPARED ON 6 POPULAR INJECTORS USED IN CORVETTES
INJECTOR LEAKDOWN RATE
TYPICAL MULTEC FAILURE
MORE BAD MULTECS (COMMON PROBLEM)
HOW TO OHM CHECK YOU INJECTORS
FLOW MATCHED BOSCH III FOR CORVETTE
85-88 STOCK BOSCH COMPARED TO THE DESIGN III BOSCH
EARLY BOSCH DESIGN II COMPARED TO DESIGN III BOSCH
LUCAS DISC VS BOSCH (BOTH NEW 30’S SPRAY PATTEN DIFFERENCE)
STOCK MULTEC COMPARED TO LUCAS DISC AND TO BOSCH DESIGN III 22lb
STOCK LT1 24lb compared to BOSCH III 24 LB
FUEL INJECTOR IN SLOW MOTION
CUSTOM INJECTOR SIZING FOR PERFORMANCE ENGINES
FOR THROTTLE BODY INJECTION
05-03-2011 10:25 AM #2Registered User
- Join Date
- May 2011
- Posts
- 42
- Feedback Score
- 0
Feel free to post up any questions you may have!
05-03-2011 01:10 PM #3
How much to have this service performed on a set of 4 inj ? Do you carry any injectors in stock for sale ? Thanks
Proven Power LLC
8602 Temple Terrace Hwy C14
Temple Terrace FL 33637
813-988-DYNO(3966)
www.ProvenPowerTampa.com
$30 DYNOJET DYNO PULLS
CHIPPING & SOCKETING/ELECTRICAL TROUBLESHOOTING/WIRING/ALARMS/AUDIO
05-03-2011 02:07 PM #4Registered User
- Join Date
- May 2011
- Posts
- 42
- Feedback Score
- 0
We carry injectors for nearly every make and model on earth, in stock, and in sizes from stock to over 300lb.
We do offer injector servicing. I'll make a new thread for it as well.
THE SERVICE INCLUDES:
1) Injectors are externally cleaned, visual inspected
2) We test injectors for resistance, shorts, and current draw.
3) We perform leak test, spray pattern, and flow rate testing on one of our 3 ASNU flow benchs. All data is recorded and sent to you.
4) Remove filter baskets, o-rings, and pintle caps. Metal injectors are bead blasted to remove old paint and rust from the injector body.
5) The injectors are placed in a heated ultrasonic bath to insure that the injector is free of dirt and contamenants that could hinder the rest of the process.
6) The injectors are now put into another ultrasonic system while they are pulsed allowing the ultrasonic energy to dislodge any particles and build-up inside the injectors.
7) The injectors are now back flowed to remove all debris, etc.
The injectors are now returned to the flow bench for retesting of all functions. The data from this test is returned to you in detail with your injectors.
9) The injectors are now refinished with high temp paint. the stainless steel injectors are polished to a high finish.
10) One of our techs. now reassembles the injector, using all new parts.
11) The injectors are then vac sealed and packaged for shipment along with the old parts.
Prices are
$15 per injector for top feed
$20 per injector for side feed.
Shop pricing available for all products and services.
~Rich
05-03-2011 02:12 PM #5Registered User
- Join Date
- May 2011
- Posts
- 42
- Feedback Score
- 0
Fixed the videos, realized they were duplicated on the last few, sorry bout that!
~Rich
Thread Information
Users Browsing this Thread
LinkBack URL
About LinkBacks
