+ Reply to Thread
Results 1 to 5 of 5
Thread: T5 rebuild questions
01-28-2012 07:53 PM #1blown
- Join Date
- Aug 2006
- Posts
- 247
- Feedback Score
- 3 (100%)
I have a T5 trans, I don't know what year it is, but it's from fox 5.0 mustang. The ID tag on tailshaft is missing, it's not world class (or at least it does not say it anywhere). I am looking to rebuild it and looking at this kit: M-7000-A Ford Racing M-7000-A Ford Racing Super Duty 5-Speed T5 Transmission
It says it's for world class, will it work on my trans?
Also is there any special tools required for the rebuild? Do I have to press anything out?
I wanted to rebuild it myself if possible, if not I will have to find someone.
01-28-2012 08:12 PM #2
IMO the non WC, T5s aren't that swift. Here's an article that might help you out. They aren't that difficult to rebuild but IMO you should hunt for at least a WC T5.
If it says WC T5 , it probably won't work on your car.
Ford began using the Borg-Warner designed T5 in small passenger cars in the early 80's. However these early non-World class (NWC) models weren't suited to handle the power of modified V8 engines, and it wasn't until the availability of the World-Class (WC) T5 gearboxes designed for the new fuel injected 5.0L Mustangs that the popularity of the transmission took off. Compared to NWC T5's the WC's benefit from needle bearings under the gears and tapered roller countershaft bearings for reduced friction. This change also allows the later to run considerable less viscous ATF fluid rather than heavy gear oil. The blocking rings are upgraded from brass to fiber lined steel for smoother gear synchronization. The early WC T5 versions were rated to handle 265 lb-ft of torque, while subsequent changes to gear material and size in 1990 bumped the torque rating to 300 lb-ft. The 1993 Cobra T5 was rated to handle 310 lb-ft, while Ford Racing's aftermarket "T5-Z" could handle 335 lb-ft as a result of a smaller first gear (2.95:1 compared to 3.35:1) and stronger steel.
T5 Transmission Rebuild - G-Force T5 - Modern Driveline - FordMuscle
01-28-2012 09:14 PM #3blown
- Join Date
- Aug 2006
- Posts
- 247
- Feedback Score
- 3 (100%)
Thanks for the link, I took a closer look at it and it says Timken on the countershaft bearing race. So it is a World Class T5.
01-28-2012 09:15 PM #4
Merry Christmas
Take a lot of pics if this is your first trans, lay everything out on a clean table where it won't be disturbed. Like I said, a little complicated, but not overwhelmingly so.Last edited by blacksheep-1; 01-28-2012 at 09:20 PM.
02-02-2012 07:15 PM #5
Call Dave Piercey at Mustang Performance, best T5 guy around as well as setting up gears.
SLEEPER
Thread Information
Users Browsing this Thread
LinkBack URL
About LinkBacks
