+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
  1. #1
    Registered User 50Mustang has a reputation beyond repute 50Mustang has a reputation beyond repute 50Mustang has a reputation beyond repute 50Mustang has a reputation beyond repute 50Mustang has a reputation beyond repute 50Mustang has a reputation beyond repute 50Mustang has a reputation beyond repute 50Mustang has a reputation beyond repute 50Mustang has a reputation beyond repute 50Mustang has a reputation beyond repute 50Mustang has a reputation beyond repute
    Join Date
    Mar 2011
    Location
    Clearwater FL
    Posts
    213
    Feedback Score
    5 (100%)
    gotta quick fox 5 lug swap question
    do you use the sn 95 brake hoses with the fox conversion brake fitting...
    or use the fox hoses with the sn95 banjo bolts?
    not sure how to do i am currently waiting on lower ball joint and and powder coating on the calipers before reassembly.
    ne quick ideas on how to remove the old ball joints? they seem like a pain in the ass to remove any help is greatly appreciated.
  2. #2
    h9 harold harper has a reputation beyond repute harold harper has a reputation beyond repute harold harper has a reputation beyond repute harold harper has a reputation beyond repute harold harper has a reputation beyond repute harold harper has a reputation beyond repute harold harper has a reputation beyond repute harold harper has a reputation beyond repute harold harper has a reputation beyond repute harold harper has a reputation beyond repute harold harper has a reputation beyond repute harold harper's Avatar
    Join Date
    Jul 2006
    Location
    I can make it faste rwith stock parts!!!
    Posts
    1,886
    Feedback Score
    28 (100%)
    u use the s/n95 brake lines,passenger side has a different fitting on thee hard line. u will have to use a adapter or cut the end off the steel line and slip the new fitting on and re flare the line. there is a tool to remove them but it would be easier to remove the control arms and take them to a shop. they can press out the old ones and install the new ones. try all american street cars. na306stang owns the the places and is in the tr shops section. he can get it done for you.
  3. #3
    Join Date
    Mar 2011
    Location
    Clearwater FL
    Posts
    213
    Feedback Score
    5 (100%)
    so i can't use the banjo bolt from the sn95 calipers with the current fox lines? i have read alot of articles that they say they do that and them i read some who use the adapter. i just need to know what would be the best way before i order new brake lines i either need new fox brake lines both sides or new sn95 brake lines both sides.
  4. #4
    What? SVT1996Cobra has a reputation beyond repute SVT1996Cobra has a reputation beyond repute SVT1996Cobra has a reputation beyond repute SVT1996Cobra has a reputation beyond repute SVT1996Cobra has a reputation beyond repute SVT1996Cobra has a reputation beyond repute SVT1996Cobra has a reputation beyond repute SVT1996Cobra has a reputation beyond repute SVT1996Cobra has a reputation beyond repute SVT1996Cobra has a reputation beyond repute SVT1996Cobra has a reputation beyond repute SVT1996Cobra's Avatar
    Join Date
    Apr 2004
    Location
    Lakeland
    Posts
    1,089
    Feedback Score
    3 (100%)
    use sn95 lines with 94+ calipers. Go to napa and ask for a Weatherhead 7828 fitting for the passenger side line.
    As for the balljoint, goto advance and use their loan-a-tool balljoint removal tool.
  5. #5
    Join Date
    Apr 2004
    Location
    Lakeland
    Posts
    1,089
    Feedback Score
    3 (100%)
    also, if changing balljoints now, go with 94+ balljoints so you don't have to use spacers for the castle nut.
    All this if if you're using 94+ spindles & calipers BTW
  6. #6
    Join Date
    Mar 2011
    Location
    Clearwater FL
    Posts
    213
    Feedback Score
    5 (100%)
    already ordered the fox ball joints. can i just use spacers or would it be best to order 95 ball joints? i am using ranger drums and 95 gt spindles hubs calipers ect.
  7. #7
    Join Date
    Jul 2006
    Location
    Posts
    1,886
    Feedback Score
    28 (100%)
    stack so big flat washers on it and put the nut and cotter pin on.
  8. #8
    Join Date
    Mar 2011
    Location
    Clearwater FL
    Posts
    213
    Feedback Score
    5 (100%)
    they should be grade 8 washers correct? totaling.333 in from what i have been reading.
  9. #9
    Join Date
    Apr 2004
    Location
    Lakeland
    Posts
    1,089
    Feedback Score
    3 (100%)
    Correct, 5/8" grade 8 washers totaling .330" (roughly 3 thick washers)
    If you can, return the fox balljoints and get sn95 instead, that would be the "correct" way since you are changing balljoints anyways.
  10. #10
    Registered User Hurstmeister has a reputation beyond repute Hurstmeister has a reputation beyond repute Hurstmeister has a reputation beyond repute Hurstmeister has a reputation beyond repute Hurstmeister has a reputation beyond repute Hurstmeister has a reputation beyond repute Hurstmeister has a reputation beyond repute Hurstmeister has a reputation beyond repute Hurstmeister has a reputation beyond repute Hurstmeister has a reputation beyond repute Hurstmeister has a reputation beyond repute
    Join Date
    Mar 2008
    Location
    NPR
    Posts
    3,488
    Feedback Score
    11 (100%)
    Quote Originally Posted by 50Mustang View Post
    Here is a picture of mine.
    This is fox a-arm with fox ball joint. The spindle/hub/caliper is from a 96 Cobra.
    See how deep the castle nut goes. It cant torque the spindle/hub down to the ball joint by itself. The nut and ball joint end up into the strut. As it sits you really cant get much of a wrench on it. It would be easier with SN95 ball joints. Though as stated it can be done using washers to shim it up.
    This was just to show an example.
    I will have the AJE k-member with tubular a-arms with sn95 ball joints when done.
    Hope this helps.
    Hurst
    Quote Originally Posted by Tiffiny
    "We all heart the Hurst"
  11. #11
    Join Date
    Mar 2011
    Location
    Clearwater FL
    Posts
    213
    Feedback Score
    5 (100%)
    i don't see a spring in your setup are you running coil overs? and i already sogned for the fox ball joint to send them back would cost 6 shipping plus a 20% restock fee and by the time its over i would only be getting 7 dollars back ill just shim them up i guess
  12. #12
    Join Date
    Mar 2008
    Location
    NPR
    Posts
    3,488
    Feedback Score
    11 (100%)
    Yes, coil overs front and rear.
    I was only suggesting that if it wasnt too late that the SN95 ball joint would be the best way to go. I thought you just got them from the parts store. Thats where I usually go for them. Certainly not the only way to go. You will be fine shimming them up.
    Hurst
  13. #13
    Join Date
    Mar 2011
    Location
    Clearwater FL
    Posts
    213
    Feedback Score
    5 (100%)
    yeah grade 8 washers minimum .330 in thick total. and i am running 10in wide rims out back is that going to rub the shock? or should it be ok?
  14. #14
    Join Date
    Mar 2008
    Location
    NPR
    Posts
    3,488
    Feedback Score
    11 (100%)
    With stock suspension and fox length axles out back 10" rim with a 6.5 back space will fit. You will need to remove the quads as they will be in the way. The stock lowers should be replaced with aftermarket that have the round bushings or you will experience severe wheel hop during hard acceleration.
    If you go with 17" rims you can try a 315/35 tire but be weary that certain brands are wider than others. You will more than likely need to employ the BFH mod to the inner fender well to get a 315 tire to fit with out rubbing. If you go with 18" wheels I would not go wider than a 285 or 295 tire at the most. Bare in mind that Mustangs are very light in the rear. When you go with wide tires (Front and rear) the car will be prone to hydroplaning during rainy weather. It happens when you least expect it and it doesnt take a lot of water for it to happen. I have had it happen to me twice. I have learned to slow it down in the rain or risk losing my ride.
    Hurst
  15. #15
    Join Date
    Mar 2011
    Location
    Clearwater FL
    Posts
    213
    Feedback Score
    5 (100%)
    i don't wanna sound like a dumb ass but what is a quad and how do i remove it? and what stock lowers are to be replaced?
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
