+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    Registered User st pete chad has a reputation beyond repute st pete chad has a reputation beyond repute st pete chad has a reputation beyond repute st pete chad has a reputation beyond repute st pete chad has a reputation beyond repute st pete chad has a reputation beyond repute st pete chad has a reputation beyond repute st pete chad has a reputation beyond repute st pete chad has a reputation beyond repute st pete chad has a reputation beyond repute st pete chad has a reputation beyond repute st pete chad's Avatar
    Join Date
    Aug 2009
    Posts
    2,125
    Feedback Score
    9 (100%)
    what locker is this?
    ok so i took the cover off today to find out what gear i had in my car because marking the drive shaft and seeing how many times it spins just didnt work.so i ttok it off and found out its a 3.73 but i also seen that a few bolts were broken and that when i spin 1 wheel by hand the other one does not move if anyone knows anything about lockers and gears let me know what the 2 broken bolts might be doing.you can see 1 of the pics the head is broken off the other one its broke deep inside and just hanging.the car was not making any noise at all i just took it off to see what gear ratio i had in the car and this is what i would
  2. #2
    Registered User blacksheep-1 has a reputation beyond repute blacksheep-1 has a reputation beyond repute blacksheep-1 has a reputation beyond repute blacksheep-1 has a reputation beyond repute blacksheep-1 has a reputation beyond repute blacksheep-1 has a reputation beyond repute blacksheep-1 has a reputation beyond repute blacksheep-1 has a reputation beyond repute blacksheep-1 has a reputation beyond repute blacksheep-1 has a reputation beyond repute blacksheep-1 has a reputation beyond repute blacksheep-1's Avatar
    Join Date
    Oct 2007
    Location
    webster, fl
    Posts
    5,834
    Feedback Score
    9 (100%)
    It looks like it may be a KAAZ, but they mostly make stuff for riceburners..stand bye
    maybe?...a Drexler? (scroll down) http://www.drexler-motorsport.com.au/products.html
    Whatever the case, I have several Ford units lying around, back in the day (late 60s early 70s) it was rumored that the Nelson bros that ran a very competitive Gasser Camaro used a welded rearend. From that time on welded diffs have been called "Largo lockers".
    Anyway. I'm assuming that the broken bolt holds the pin that goes through the center of the carrier (probably under the snap rings) you may end up beating the living hell out of this thing to get it apart. In any case remove those snap rings and see what's there, you can rotate the assembly? right?
  3. #3
    Join Date
    Aug 2009
    Posts
    2,125
    Feedback Score
    9 (100%)
    Quote Originally Posted by blacksheep-1 View Post
    maybe?...a Drexler? (scroll down) Products ? DREXLER MOTORSPORT AUSTRALIA ? Limited Slip Differentials
    i think i found out what it is.its a detroit truelock .
    yes i can rotate it i was driving it and never knew anything was wrong with it drives perfect
  4. #4
    Join Date
    Oct 2007
    Location
    webster, fl
    Posts
    5,834
    Feedback Score
    9 (100%)
    As I recall it might be fine (once you fix the broken bolts) the last Detroit Locker I ran (about 1974) you had to do a "chirpy" with it, in a straight line before your run. I know that they were absolutely bullet proof but had some bizzare characteristics that you had to deal with.
    I guess they are now owned by Eaton
  5. #5
    Join Date
    Aug 2009
    Posts
    2,125
    Feedback Score
    9 (100%)
    yea eaton took over a while back from what i was reading today
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
