#17 (permalink) |
drives a slow car
Car: 95 Mustang Cobra, 67 mustang cp, 94 vert V-6
ummm tampa? LOL
: 2147483647 |
The plugs never lie, so "listen" to them before the computer.
Hurst said it well. (even if he was a bit long winded while doing it) LOL I dislike my 95 Cobra because I can't tune it like I can my 67. If I want to do anything to my cobra, I have to take it to the tuner and let him massage my baby. It's kinda like taking your GF to another guy to bang her for you. I hate it, and therefore haven't had it done yet. My 67, however, I have banged many times myself, and have NEVER allowed anyone else to molest. |
#20 (permalink) |
Team Geritol Racing
Car: '91 Mustang Coupe
Largo
: 2147483647 |
Exhaust leaks will make the wideband show lean. Also, you may be OK at some Load/RPM's and lean at one or more Load/RPM's. It's the occasional lean spot that's gonna get you. Fuel and spark adders come into play too. They are based on ECT, ACT barometric readings load, RPM, Open Loop or Closed loop etc. The more things yo can adjust, the closer you can get your tune. Screwing around with just fuel pressure and timing ain't gonna make it. Today's good tune may kill you next week. OTOH, being able to muck around with your computer code can also give you a million and one ways to blow it up.
#25 (permalink) |
Team Geritol Racing
Largo
: 2147483647 |
Yeah, carbs are cool. I especially like them when the floats stick and they start barfing fuel everywhere. Power valves, jets, bleeders, squirters. Yeah I remember when my carb parts box weighed more than my tool box. They work...but they should...they have more experience than EFI. OTOH, Commodore 64's work too.
#26 (permalink) |
Car:
NPR
: 1542437707 |
Carb Hater. Dont be hatin homey. Carbs are the new EFI. Its a perfect circle. I honestly believe there is a reason carbs still dominate the sport of racing. Think of them as the 5.0. They've been around so long,.. its like how fast you wanna go? Yeah,.. ok,.. here ya go,.. this will do exactly what you want. Proven formula's that have already had the guess work taken out of them. They work and we know how they will work. Now there is almost a full generation that has no clue what or how a carb works,.. and they are scared of them. I've heard everything from 'Carbs dont work if its too cold outside',..to 'carbs dont work on bouncy roads',. or my favorite,. 'Carbs arent reliable'. I dont hate EFI. I just cant afford it and what comes with it. When EFI, the parts that go with it and all the tuning etc,. when those prices come down to a more realistice level I'll get back into it. Till then,.. I'll love on every carb conversion I do. And on that 86,.. I said it was half assed. Dont throw that one back in my face LoL. That car has been parted out. I just wanted to get it running because someone told me I couldnt get it running. And sorry,.. yep,.. another long winded schpeal. Heh Hurst |
#27 (permalink) |
Team Geritol Racing
Largo
: 2147483647 |
Nah, I don't hate carbs, I've owned a ton of 'em. But to tell you the truth, I'm having a heck of a good time learning the inner workins of EFI. I do find it a little amusing that you carb guys keep harping on the cost of EFI yet you have no problem dropping a couple $K on some rims and $2k for a bare block and then your butt puckers at the thought of spending money on something that will give you infinitely more control over all your other expensive parts.
In the end, it's just another one of those either/or things that will get you where you want to go. I just like the challenge of learning a little more than how to read plugs and then having to dumb the engine down to the lowest common denominator (read adjust carb to cover the leanest cylinder) in order to keep it all together. |
#28 (permalink) | |
drives a slow car
ummm tampa? LOL
: 2147483647 |
Quote:
But there's always tomorow I guess. Power valves...Same story. If the rest is taken care of, then you shouldn't have a problem. My jets, I only changed if I changed something else in the set up. (i.e. camshaft, heads, or intake. Maybe if I changed the height of the rear tires.) The squirters, I never had one get clogged. EVER. I only changed them to figure out the basic tune of the engine. Usually, it was not needed though. Let me see here, complete Holley 600 vac secondary: $232 Tuning parts: about $75 Rough total: $307 New injector set: $250 (for anything above 19 lb) Computer tune: $200-$400 (depending on who you use and how long it takes Tuning computer if you wish to do it yourself: Unknown because of so many different choices. Roughly around $250-$1200 depending You have to figure in replacing at least 2 sensors which will cost around $100 each if you're lucky also. No, I'll always like my carbs better than FI. I still respect FI though because of it's ease of use. Put it in, and if none of the sensors are bad, it fires fright up. Not usually the case with a carb. With a carb, you have to tune it for it to even run at times. But I can do the carb work myself. I can't do anything to FI myself except replace the parts/sensors and hope for the best. |
#29 (permalink) | |
Car: 89 Lx coupe
Brandon
: 1013990876 |
Quote:
Like I stated earlier, FI is great when there is a warranty involved Last edited by GNs-r-slow : 10-03-2008 at 12:13 AM. |
#30 (permalink) |
Team Geritol Racing
Largo
: 2147483647 |
Geeze, guys, I said they work. I've even got one on my lawn mower. It's got more dirt and grass in it than my yard but it keeps on ticking.
| Sponsored Links |
