Forums Register TRHelp TRGarage TRader Ratings Classifieds Search Today's Posts Mark Forums Read Calendar
iTrader Mainpage
Browse All Members
FAQ Gallery Weather Log Out
Go Back   Tampa Racing > Technical Forums > Ford Tech
Old 07-22-2008, 11:59 PM   #16 (permalink)
Car: 3 SVOs: 84 and 2 86s
Ft. Myers
SpyVO has a reputation beyond repute: 118556199
More details? Year? Miles?
Things that would turn me off when looking at an SVO:
-Rust. I'm from up north, don't want a rusty car ever again. If you see some, there will be more where you can't see it. Check the frame rails just ahead of the firewall. There was a red 86 I looked at a while ago up there that looked NICE on the outside. I was really psyched...till I saw the framerails. Shameless plug...I have a bunch of spare body parts should you need 'em...
-Torn bolsters on the driver's seat. I hate that because they make the interior look like crap, and there's really no easy way to fix it (swapping seats is easy, but finding SVO seats to swap...not as easy).
-Ripped up leather parts - shifter knob and steering wheel, mainly. Just look crappy. You can get a rubber GT wheel hoop and put the SVO center in it. Kinda ghetto, yeah, but good for a driver. Horn may need some rigging to make it work.
-Yellowed headlights. The passenger side outter marker is 'quite' expensive to replace, if you can find one. The rest are easier to find, and 'just' expensive.
-Those f'n upper wings...they look cool as hell when they're in great shape. PITA to fix - I only know one person who can do it worth a damn.
- Cracked header panels. The fiberglass behind the bumper cover. If the thing was in a light front-ender, it's pretty common to have the skin replaced, or not torn, and a cracked header panel. I think you can get a repro unit still, but it's $350 I think. It may not even bother you, but still something to look for.
-Any missing SVO parts, mostly the stuff on the outside. Like Dave said, that stuff is expensive. In fact, it kinda turned me off on SVOs altogether. Spats can be pricey, sail panels aren't too bad, door bumper trim will surprise you! $$$
-For some reason, I remember the E-brake cable being a PITA to replace if needed, so if that's important to have working, be sure to check it.
As for motor stuff, I wouldn't worry about a thing. That shit is ALL cheap. If the turbo is bad, try to get him to knock a bunch of money off the price, but don't let that keep you from getting the car. The center section is common between a bunch of other 2.3t cars, and that's all you'd need to replace (we just did one Sunday, as a matter of fact, and got the center section for free).
Same with trannys - regular 4-banger trannys work just fine, as long as they're 87 and up (Levi...?).
If the car smokes, especially on startup, my money is on it having the wrong PCV valve and/or bad valve stem seals. If there's oil on the intake side, all around the vicinity of the #4 injector, again I'd point at the PCV valve.
If when driving it, the thing is sluggish at first, then starts pulling good, then falls on it's face, they were probably messing with the boost and turned it up a bit too much.
Early cars had more bugs than later cars, from what I've seen. If it's an 84, make sure the fan kicks on when it gets hot. Early cars seemed more likely to have oil everywhere, since the PCV setup was a little different.
There's probably more, but I put all this stuff in here in case you run into a basket case. They're old now, and a LOT of them are like that at this point. And most people don't even know how to fix them, so you tend to find all kinds of whacked out crap on them by now. Even if the car LOOKS good and is truly solid, I wouldn't be suprised if there's something not right with the motor - TPS calibration, boost leak, high idle, oil leak, stumble/hesitation - use that to talk him down.
If I was looking for an SVO, I'd look for a straight body with good paint and interior. Everything else is cake. I wouldn't care if it even ran.
If you want to put my number in your phone, PM me and I'll send it to you so you can call me when your looking at it.
SpyVO is offline
Old 07-23-2008, 01:12 AM   #17 (permalink)
needs a rich uncle
Car: 86 coupe 5.0
apollo beach
Joker Instituted has a reputation beyond repute: 1043170342
^right on point. no need to say any more. a 2.3t is easy and cheap to build. as long as you find a good block and want to upgrade as much as you can with out worring about name's then you will be very happy. so like spy said for the most part, screw the motor and find your self a svo as mint as you can. the price on the car vs. the build will make up for itself.
Joker Instituted is offline
Old 07-23-2008, 05:53 AM   #18 (permalink)
is doing your girlfriend
Car:
Duceanahalf has a reputation beyond repute: 2147483647
Quote:
Originally Posted by 080715jk View Post
 北京乾锐天牧医药科技中心珠宝部成立于2003年,专门从事金缕玉衣的生产制作.本公司的金缕玉衣制作工艺由公司创始人张新海世代祖传,迄今已有有两千多年的历史。在生产制作过程中,培养出一批技术精良的 制作金缕玉衣专家.他们与徐州博物馆工作人员共同修复徐州狮子山楚王陵出土的金缕玉衣工作,历时1年零9个月,终于成功地使这件国宝恢复了原貌.经修复的金缕玉衣长1.74米,共使用玉片42 48片,金缕重1576克,是目前已发现的时间最早、玉片最多、玉质最好、工艺制作最精的金缕玉衣
:spam:
Duceanahalf is offline
Old 07-23-2008, 03:53 PM   #19 (permalink)
Another Mustang whore
Car: 95 GT, 93 LX, 91 GT, 90 coupe, Mazda and an 81 Z28!
Lakeland, armpit of the world
racingrick has a reputation beyond repute: 531982692
common to mustangs in general but a friend of mine had 2 svo's and they both had the upper control arms ripped loose at the torque boxes.........if you drive it and it seems to pull either way when shifting hard that's a big hint.
racingrick is offline
Sponsored Links
