302 problem
Old 10-14-2010, 11:25 AM
nick caldwell
caldwells99mustang's Avatar
Default 302 problem
i have a 302 in my mustang and for some reason i cant get it to stop backfiring. i have a brand new distributor on it, new wires, plugs, coil. just replaced the timing chain. all the timing is where its suppose to be. anybody have any ideas what it could be??
Old 10-14-2010, 12:58 PM
9050LX's Avatar
Check the timing with and without the spout.check compression.Check plug wires,Check computer ground.Check for vacuum leaks.Simplest things first.
Old 10-14-2010, 01:01 PM
lives in a glass house
$hawn's Avatar
wrong firing order or wired clockwise???
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old 10-14-2010, 03:16 PM
Hurstmeister's Avatar
^ This.
I made this same mistake recently.
Hurst
Originally Posted by Tiffiny
"We all heart the Hurst"
Old 10-14-2010, 07:19 PM
banana republic
95coBraSVT's Avatar
Originally Posted by Hurstmeister
^ This.
Hurst
Also guilty of that.
Originally Posted by rotarykidd
maybe i just like rainbows and puke, who says it has to be a gay thing?
Old 10-15-2010, 06:12 PM
nick caldwell
its the right firing order i even pulled all the wires off then redid them again. but what do you mean wired clockwise
Old 10-15-2010, 06:43 PM
banana republic
95coBraSVT's Avatar
Basically, you wire the dizzy correctly, but completely backwards.
Old 10-15-2010, 06:44 PM
Superwes98's Avatar
well mine back fires like freakin crazy when im slowin down from high rshared_pm
but thats because of my mufflers, or the lack there of lol
Old 10-16-2010, 03:27 PM
nick caldwell
oh nope rewired everything again today and still doing the same shit. and i forgot to mention its backfiring though the carb not the exhaust
Old 10-16-2010, 04:44 PM
banana republic
95coBraSVT's Avatar
A backfirwe through the carb is an indication of a vehicle which is firing before the valve is closing. Is is a consistent backfire? Or intermittent? If it is consistent, then I would say you have a valve stuck open. If it's intermittent, then I would say you have a sticky valve or a plug wire wrong or something. You sure you have the right firing order? There are TWO different ones for the 302 you know. And the firing order is determined by the camshaft.
EDIT* You may also have accidentally installed the timing chain a tooth off.
