The Ford Forum Lounge Off Topic Group for Ford Forum Members or other regulars. Keep it work safe please. No tech posts.
500 Horsepower NA Setup??? Help
Old 04-30-2010, 03:44 AM
BuickStangdude's Avatar
Question 500 Horsepower NA Setup??? Help
Hi folks-
I have a 91 Foxbody LX Coupe- it's nice.
It's a 306, Supercharged Fox Vortech Strim
I had a question. What can I change on the bottom end (motor) to achieve a 500 Horsepower to the rear wheel setup.
I would like to remove the whole engine, and go Natural Aspirated. Can this be done with a 347?
If you can chime in. I would like to ditch the Supercharger for now. I have a Holley Systemax intake sitting in my garage, with a brand new set of Trick Flow Twisted Wedge Heads. I'd like to have a bottom end built and put it all together-
Thanks in advance,
Mike in Central Florida
Old 04-30-2010, 05:15 AM
I can fix your bullshit
Tiffiny's Avatar
Originally Posted by BuickStangdude
Hi folks-
Thanks in advance,
It would be better and easier and about the same price to build a stroker 351 set up . it will be real hard to make 500 hp na to the wheels
with a 347....
Old 04-30-2010, 05:35 AM
Thanks for your thought
I guess I'm going to need a different block I assume then? And then have it stroked out or not?
appreciate any more thoughts, and thank you for the 351 advice. I was kind of thinking that way myself
Also, can I still use the twisted wedge heads on the 351? i'd like to stay fuel injected- so Im assuming my green 42lb injectors will also need changing out?
I have a Treme 3550 trans too
st pete chad's Avatar
i agree and i also have a nice 351w roller for sale
[IMG][/IMG]
357w s475 turbo Hughes powerglide
slowmoving1's Avatar
it can be done if your you have the funds, not cheap by any means.
302 based dart,ford racing block ,363-372 ci should get you there
high compression,high rpm
most NA 347 make about 350-400 rwhp some a little higher
Old 04-30-2010, 05:46 AM
yea but like john said for just about the same price you can go bigger 393 or 408.hell you wont spend as much money on a 351w roller block like you will a sportman or dart block
[IMG][/IMG]
Old 04-30-2010, 05:51 AM
Hi folks-
Thanks in advance,
by my 351w roller block put your heads on it put a good came in it and a nice intake and you will be on your way
[IMG][/IMG]
Old 04-30-2010, 05:56 AM
yes you can use the twisted wedge heads on the 351.however if you stroke it to a 393 or a 408 the stock out the box trick flow heads will be small but can still be used.as for the 42lb if you stroke it the 42 should be ok.im building a 351w turbo now with trick flow heads but mine have been ported.i would get a 351w roller block mine throw your heads on it sell the holley intake buy something for a 351w put a nice cam in it and you should be on your way.as for the tremec 3550 you should be fine.i know a guy with a 351w roller trick flow heads stage 2 ported from fox lake victor intake custom cam with all the bolt on and hes making 480@ wheels
[IMG][/IMG]
Old 04-30-2010, 08:38 AM
slow306stang's Avatar
we made a estimated 463hp with
a 750hp holley, victor jr intake, cast trickflow twisted wedge heads, cp flat top pistons, eagle rods, and crank, with a custom ground 544 lift comp cam.
and have ran 10.90's with it.
daily
1988 fiero gt, stock and slow
race car
1989 mustang lx, n/a 8.2 deck 302 block, just your average street car.
project
1973 plymouth 340 'cuda
refinish artist
351coupe's Avatar
Your gonna need to build one nasty 347 for 500n/a whp.
Visit my TR Shop Forum
RIP Chester P.Anderson Jr.9/23/05 I love you dad,and miss you very much.
RIP Kevin"Slo SI" 9/13/06,we will miss you homie,time heals wounds but you will never be forgotten
