#1 (permalink) |
Car:
: 3937154 |
Services
WE DO FULL POWDER COATING AND ALSO DO CERAMIC COATING.
HERE ARE SOME OF ARE PRICES ALSO REMEMBER I WILL BEAT ALL OTHER POWDER COATERS PRICES IF YOU FIND THEM CHEAPER THAN ME. MEDIA BLASTING we do media blasting so if u would like your part to look like new we can make it happen. CUSTOM WORK we also cut valve covers to show your cam gears. we do not recommend the the whole cam cover be remove for possible debris getting in your timing belt. if you do select this to be done we ask you to sign a waver to cover use. Something we have to do sorry. $20 CUSTOM PAINTING WE DO CUSTOM PAINTING FOR YOU THAT WANT A PERFECT MATCH TO YOUR CAR. WE ALSO DO CUSTOM WORK FAR AS DOING PAINT WORK ON VALVE COVERS WHERE IT WOULD TAKE TO MUCH TIME AND COST TO MUCH. WE ALSO DO INTERIOR PARTS AND TAIL LIGHT SMOKING. ASK USE WHAT YOU WANT DONE AND SEE WHAT WE CAN DO THANKS. SHAVING We can also shave valve covers and other items. contact use for pricing due to different price on what we have to remove. clear powder coating $20-$40 we recommend this to be done on polished parts this will keep the item from finger prints staining an oxidizing. the item will always look new and not much to do when you got to a show but to wipe it down. never polish again. Valve Covers $50 single stage colors $75 two stage colors $20 clear coat recommended for UV protection and more chemical resistant. Intake Manifolds $40 single stage colors $60 two stage colors $20 clear coat recommended for UV protection and more chemical resistant. Front Brake Calipers $55 single stage colors $80 two stage colors $20 clear coat recommended for UV protection and more chemical resistant. Rear Brake Calipers $40 single stage colors $60 two stage colors $20 clear coat recommended for UV protection and more chemical resistant. piping $15 per ft single stage colors (up to 3.5 foot) $22.50 per ft two stage colors (up to 3.5 foot ) $20 for clear coat recommended for UV protection and more chemical resistant. wheels 15" $55 (each) 16" $60 (each) 17" $65 (each) 18" $75 (each) HIGH TEMP CERAMIC COATINGS. CHROME 1300-DEG. WHITE 2000-DEG. TITANIUM 2000-DEG. BLACK SATIN 2000-DEG CAST IRON 2000-DEG. ALUMINUM 2000-DEG. STOCK MANIFOLD $65 $90 HEADER $75 $95 8-CLY STOCK MANIFOLD $125 $150 TURBO/SHORTIE'S $150 $175 LONG TUBES $200 $250 HIGH TEMP POWDER COATINGS 1000 Degrees Resistant Smooth Black 1000 Degrees Resistant Black Texture 1000 Degrees Resistant Silver Texture STOCK MANIFOLD $50 $70 HEADER $60 $80 8-CLY STOCK MANIFOLD $100 $140 TURBO/SHORTIE'S $120 $160 LONG TUBES $180 $220 SPECIAL ORDER COLORS The price for special orders is based on the color type an how much is required for your item. Shipping prices Valve Covers: $15 in the US other items are based on your location and whats being shipped size an weight. core charge we charge a $45 core on valve covers that we have in stock for cores. you will receive your core charge back when we get your core back in from you. your core must be in the same condition as you receive ares. we mean that it must not have dings / dents / gouges / cracks / chips. Last edited by 92mugenintegra : 11-12-2007 at 08:07 PM. |
#9 (permalink) |
Car:
: 3937154 |
send me a pick of the part so i can give you a correct price. i warranty all my work for a 1 year. thanks josh
| Sponsored Links |
