#1 (permalink) |
Car:
: 72489999 |
1000hp++ 2jzge (probably going to take 2 years)
so i bought a 1992 sc300 about a year ago. i was going to drive it stock, but instead i'm going to build the piss out of it and race it. as if i didn't need anything else to spend my money on.
i'm a broke fool, so its probably going to take the better part of two years. i figured i would start posting pics as i go, so it probably won't get exciting until i start building stuff. either way, plan so far: ported head by jay greene "greenmonstah" brain crower springs and retainers fsrmotorsports.com custom cam grind Groden aluminum rods stock crank head & main studs 10:1 compression cp pistons 2jz-gte oil pump Bullseye Power (borg warner) s380, 1.25 turbine, race cover bottom mount divided t4 manifold - DC exclusive 50mm turbosmart racegate wastegate 50mm turbosmart raceport bov 4~5 inch downpipe (can't decide) - DC exclusive 4~5 inch aluminum exhaust - DC exclusive 2000hp air to water intercooler setup- DC exclusive semi-sheet metal intake - DC exclusive 80mm wilson throttle body Electromotive tec3r electromotive 2jz-gte trigger wheel twin custom fuel rails, 450 cc primary, 1600 cc secondary - DC exclusive 10an fuel system with either custom sump or fuel cell - DC exlcusive 1035 weldon pump with pre & post filters followed by weldon regulator transmission is the only thing that i'm not particularly sure about yet. not sure if i'm going with a v160, th400 or pg. depends on cost i guess. i have a lot of time before that will be a problem, so i'm not too worried about it. i've got a r154 and can convert it,so i might do that until i figure out a sound tranny combo. either way, here are some pics of the car and my engine being torn down. i already sent the head out (thanks jay) and should have that back in a month. i'll probably build the intake first followed by the exhaust stuff while i'm saving for the engine managment. enjoy! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#8 (permalink) | |
Car:
: 72489999 |
Quote:
those were pics from when i worked in savannah. super awsome mk3 yo! yeah, i'm definatly trying to compinsate. funny....... wondering why you havn't posted pics up of your twin gt42's for you sc400? |
#9 (permalink) |
Bakermotorsource
Car: Another SC400
Ellenton, FL
: 308016716 |
Someone hasn't built the manifolds yet!!! but with me actually liking the new SC400 I bought (no one has seen it yet but its gold) I will feel better dumping money into it.
| Sponsored Links |
