Forums Register TRHelp TRGarage TRader Ratings Classifieds Search Today's Posts Mark Forums Read Calendar
iTrader Mainpage
Browse All Members
FAQ Gallery Weather Log Out
Go Back   Tampa Racing > TR Shops > TR Shop Forums > Driven Concepts
Closed Thread
Old 11-12-2007, 03:11 AM   #1 (permalink)
TR Registered Member #5
Car: 72 datsun 510, 94 Accord, 07 350z, 91 240sx
Oceanside, CA
marksaccord95 has a reputation beyond repute: 269223769
so since my car is playing musical shops....
can u all finish it now? Can Chris wetsand it now?
i just want to drive it, whaaaaaah.
I need to get a stock SR ecu to scott so he can rom tune it, i dont wanna do the megasquirt anymore. also need that z32 maf, ignitor and an SR20 harness and get it running.
i sent over a list of what it needs. steve baker is gonna come check out the car for the wiring unless someone there they can do it perfectly, but id probably rather have steve do it.
it seriously has like 2-4 days max worth of work that needs to be done to it.
need to get interior for it, any ideas?
also, i need to get my shitbox accord that sitting there sold, any ideas?
marksaccord95 is offline
Old 11-12-2007, 03:20 AM   #2 (permalink)
Oceanside, CA
carbon fiber plating between the radiator and core support, carbon fiber fitted where the stock tach/speedo goes on the refinished dash, defi tach installed and AEM wideband, still need to purchase
rest of the shit i dont know whats been done by sean, so i guess it all needs to be checked
- finish seat mounting sean started
- mount and setup CNC hydrolic e brake, in front of the shifter, pull style
-Dash air vents on the mint dash pieces sanded and painted duplicolor chrome (or some variant)
-Dash harness to make everything work, from turn signals to windshield wipers.
-Engine harness working
-turbo feed and return lines, flange and seal for return are there, you use the judgement on going AN or rubber return.
-Catch can mounted, lines finished
- 7/8ths 280zx brake master cylinder, dual tube style (late model) brand new. They come as for power brakes, in a zip lock bag is what is needed to convert it (plunger, clip, boot, etc) to a manual brake, i know the master is in there, dunno if the plunger is in yet
-any finished welding on the floor pans
-lower harness
-battery relocation kit ran
-right rear trailing arm shock mount threads are fucked up. Threads need to be retapped.
- you will see that the trailing arm mounting points are slotted, the vertical ones are for camber adjustment, pry bar them all the way down and impact them on. Horizontal are the toe adjustment, try to eyeball the center and then tighten. Check to make sure the tires don’t rub the inner fenders, I believe they rub A LITTLE, shave the inners if need be. Reapply 3M undercoating spray where ground.
- vent tube for gas tank.
- when powering the fuel pump, check everything for leaks
-when running the motor check everything for leaks, new front and rear main seals
- fluids, water wetter for radiator, motul brake fluid (mastro Subaru), diff fluid, qt of shock proof for trans and whatever goes accordingly, ensure the KN filter for the engine I got is correct, 20w50 of whatever non synthetic but good fluid
-the 2 vacuum lines going in the drivers side is for the AVCR boost solenoid, should have push locks for them, if not, the local hydrolic place there has the eaton fittings.
- the vacuum line coming from the intake manifold is for the ECU and AVCR boost solenoid. Figure a correct way to T the push lock lines into those normal rubber lines, there is a extra push lock T in the car.
-The water temp defi mounted in the small hole in the middle of the guage cluster area, the temp sensor is in my coolant bypass neck.
- Need new rear brake T block and new lines for the rear in stainless.
-Front brake lines, there is the little joint on the old lines in the box that C clips to the body, re make new stainless front lines
wire the car for a dimmer, power, ground, tach and speedo wires for when I put the autometer digital gauges.
- Wire AVCR for speed and rpm
- Gas tank vent tube
- nice coolant overflow tank
-im unsure what bulbs in the car are good or not
-install new dash cover and refinished dash parts
Old 11-12-2007, 08:01 AM   #3 (permalink)
Saddlebrook
Car: Lexus SC400/LS400
Wesley Chapel
Griffin400 has a reputation beyond repute: 365359220
any thing else???? Maybe a cup of tea with two lumps of sugar and a cookie????!!!!
i keed , i keed!
Griffin400 is offline
Old 11-12-2007, 08:09 AM   #4 (permalink)
Driven Concepts, Tampa FL
Car: 03 M45, 98 GS300, 94 Supra, 04 Silverado SS, 05 GSXR1000, 01 TL1000R, 04 GSXR600, a few more
Wesley Chapel, FL
SpottedMango has a reputation beyond repute: 403593948
I actually read all this........
-lower harness
SpottedMango is offline
Old 11-12-2007, 08:11 AM   #5 (permalink)
Saddlebrook
Wesley Chapel
Mark, give me details on the accord and i will snap some pics and post it up.
Old 11-12-2007, 08:11 AM   #6 (permalink)
Wesley Chapel, FL
Damn, already trying to avoid a LARGE BILL..........
Old 11-12-2007, 08:15 AM   #7 (permalink)
Saddlebrook
Wesley Chapel
Hey its Mark....for him its free.....
....NOT!!!!
Old 11-12-2007, 03:57 PM   #8 (permalink)
Oceanside, CA
Quote:
94 accord, newer motor. EX with sunroof and all power, new timing and balance belt. motor runs perfect, transmission locked up, needs new trans.
$1400 obo
Old 11-12-2007, 03:57 PM   #9 (permalink)
Oceanside, CA
Quote:
if u read it, its actually justa bunch of small shit for the most part.
Old 11-16-2007, 02:50 AM   #10 (permalink)
Oceanside, CA
Old 11-16-2007, 07:57 AM   #11 (permalink)
Wesley Chapel, FL
Finishing up on some projects this week. Will have Mike sit down and take a good look at the project Monday.
Old 11-20-2007, 12:59 AM   #12 (permalink)
Oceanside, CA
howd that turn out
Old 11-20-2007, 11:51 PM   #13 (permalink)
Car:
manifoldmike has a reputation beyond repute: 151980596
howd that turn out
balls to the wall. didn't happen yet. i'll take a look as soon as i can.
manifoldmike is offline
Old 11-28-2007, 12:45 PM   #14 (permalink)
Oceanside, CA
cough
Old 11-28-2007, 09:31 PM   #15 (permalink)
Car: 1993 RSP/RHD Supra
memole has a reputation beyond repute: 318162644
you need to turn your head first...then cough...lol
Just me
Chris
memole is offline
Sponsored Links
Closed Thread
