#1 (permalink) |
Car:
tampa
: 396 |
Fuel setup
i'm looking to get a fuel setup in a 2nd gen rx-7.
I just need the parts... such as fuel cell ( drift friendly), braided lines, fittings, and external or internal fuel pump and regulator. the car currently does not run, but i can take measurements. possible to get a qoute or will i have to bring the car in? |
#2 (permalink) |
TR Administrator
Car: 95 Supra Turbo, 350Z, S60
Tampa, FL
: 1549719766 |
If you can supply us with the measurements then there is no need for the car to be here. The only measurements you really need are the length of the fuel line and the amount of space you have to accommodate the fuel cell. If you can supply me with those measurements I will shoot you a quote via PM.
#3 (permalink) |
Car:
tampa
: 396 |
12inches tall, 36 inches from driver to passenger side, 18 inches from front to rear
thats the space i have to work with in the trunk... for the fuel line, that would depend on internal or external fuel pump. i'd say 10 feet so i can have spare room to work with either way. |
#9 (permalink) |
Boom Chackalacka
Car: Daily Beater, 96 civic HX-T, 94 TT MKIV, 06 Honda Accord
: 99352104 |
Sump both tank and have an external pump. Feeding is the easy part.
Deciding the return and how to make sure that the tanks stay level is a bit more interesting. The way we do it on the diesel rigs would probably be the safest bet. You'll need an extra sump line between the two tanks to make sure that one does not start passing air to the feed lines. edit and you'll need another line between the top of the tanks to equalize pressure. /edit No reason it wouldn't work. No real ineficiency I can think of besides extra work and more money. My $.02. Ok... I'm going home now. bye! Last edited by pheobo : 04-10-2007 at 12:35 AM. |
#11 (permalink) |
Car:
tampa
: 396 |
dual does sound a bit tricky. i'm sure i can come up with a nice custom way for a single fuel cell to fit in there. a bit of cutting here and there and voila.
it would just have to be no taller than 12 inches... Last edited by TheGrim : 04-10-2007 at 11:04 AM. |
#14 (permalink) |
has whippled VTEC
Car: 216FWHP of awesomness
riverview
: 2147483647 |
Wow your really limited on space!Well how bad do you need that passenger seat, If your real hardcore the thought of riding with 10 gallons of race fuel right next to you wont bother you and if your like me you'll still smoke in the car, J/K.Good luck man hope yopu figure it out.
#15 (permalink) |
Car:
tampa
: 396 |
hmmm, i'll be running on pump gas most of the time. need a passenger seat because its also a daily driver. i'd like 10-14 gallon tank... having to refill more than once a week eats cash like crazy.
| Sponsored Links |
