#3 (permalink) |
TR Administrator
Car: 95 Supra Turbo, 350Z, S60
Tampa, FL
: 1549719766 |
No sir, I keep both wires separate. After the relays you can run the wires to a distribution block and run a thicker gauge wire to the battery.
You CAN splice both of them together in tank but make sure the wire coming out of the plug is a thick gauge wire..that way you can run 1 relay for both pumps. I just like to keep them separate to make things safer, I wouldn't want both pumps going out at once if a short was to happen. |
| Sponsored Links |
