Forums Register TRHelp TRGarage TRader Ratings Classifieds Search Today's Posts Mark Forums Read Calendar
iTrader Mainpage
Browse All Members
FAQ Gallery Weather Log Out
Go Back   Tampa Racing > Motorsports & General Tech > Drifting > Drifting Tech
Old 03-04-2008, 11:52 AM   #1 (permalink)
PashiMotorsports™
Car:
pashi is on a distinguished road: 1248
Cable E-Brake to Hydraulic Conversion?
Im planning to use a KSport hydraulic e-brake on my drift car but it came with the stock cable e-brake.
Has anyone done a conversion like this before, please give me the info..
Thanks
-pashi
pashi is offline
Old 03-05-2008, 11:41 PM   #2 (permalink)
eats gunpowder
Car: Drift Ambulance
mranlet has a reputation beyond repute: 76002306
What are you trying to do? Install a Ksport Ebrake?
mranlet is offline
Old 03-06-2008, 02:23 PM   #3 (permalink)
PashiMotorsports™
Car:
KSport is what i had in mind but it doesnt matter what kind of hydraulic e-brake it is..
i just want to know what i need to do to have a hydraulic e-brake, but the car comes with a cable e-brake.. cable to hydraulic?? possible.. yes - practical???
-pashi
pashi is offline
Old 03-07-2008, 01:45 PM   #4 (permalink)
doin big thangs
Car: s13
st pete
RyanS13 has a reputation beyond repute: 385166124
what the hell do you need hydraulic for, cable is just fine and does the job, unless your going to fd or d1 or nopi maybe but cable is just fine, imo
RyanS13 is offline
Old 03-07-2008, 10:10 PM   #5 (permalink)
PashiMotorsports™
Car:
Quote:
Im going to remount the ebrake lever so i was wonderig to switch it to hydraulic for les linkage.. i gues ill stay with the cable and reweld the center console for the ebrake lever.
besides, itll look sicker with new linkage fabrication..
-pashi
pashi is offline
Old 03-07-2008, 11:21 PM   #6 (permalink)
eats gunpowder
There is less involved with a cable ebrake than there is with a hydraulic for damn sure. The Ksport is OK but forget about a center console and have fun with that installation and bleeding. I've used a modified stock Ebrake lever and made my own with inline master cylinder and everything fitting under the center console. Unless you know it's there you would never have any idea:
Realistically, I'd say that I could build you one for $450 installed, or you could buy the components for $250ish and figure it out for yourself.
Where/why are you remounting the ebrake? Staging style?
mranlet is offline
Old 03-08-2008, 11:09 AM   #7 (permalink)
PashiMotorsports™
Car:
im mounting it onthe right side of the shifter, just a little below.. refabricated lever going straight up.. kinda like in that pic only mounted straight up and in more comfortable place..
the E36 center console is very skiny so ill weld a bracket for it.. cant really explain, once im done ill get some pics.. i just need a best way to extend the ebrake cable..
thank you for ur offer tho..
-PASHI
pashi is offline
Old 03-10-2008, 11:06 PM   #8 (permalink)
tire eater
Car: '97 Dodge Cummins, 1991 240sx SR
Largo
box240mod has a reputation beyond repute: 77058983
if you screw it up = no foot brake until you fix it, since you run it into the main brake lines. GL, i like my cable
box240mod is offline
Old 03-13-2008, 06:15 PM   #9 (permalink)
Infidel
Car: 86 & 93 Notch
Tampa/St Pete
KAILUAZ has a reputation beyond repute: 1683269343
Interesting, does this just tap into the stock rear brake line with a "T" fitting?
KAILUAZ is offline
Old 03-28-2008, 07:19 PM   #10 (permalink)
^ likes 2.4l's
Car: 93 d21 project never run 90 929s DD/drift toy
New Port Richey
IThaJokaI has a reputation beyond repute: 432958597
Thats pretty baller Mike... Might talk to you when its time to do my hand e-brake install...
IThaJokaI is offline
Old 03-30-2008, 08:48 PM   #11 (permalink)
Infidel
Car: 86 & 93 Notch
Tampa/St Pete
Here is an interesting thread:
Hydraulic E-Brake ! - DriftCentral Forums
KAILUAZ is offline
Old 04-01-2008, 12:37 PM   #12 (permalink)
Yoshimi_Drift
Car: Nissan 240SX
813
angelgoya has a reputation beyond repute: 13864133
i have a question,
my E-brake is really loose, how can i make it tighter??? I've done it on a civic but im pretty sure is not the same with a 240
angelgoya is offline
Old 04-01-2008, 11:00 PM   #13 (permalink)
doin big thangs
Car: s13
st pete
yank it up and tighten the 10, they mostly all work the same
RyanS13 is offline
Sponsored Links
