#1 (permalink) |
brotary
Car: death machine
WC/LOL
: 140171300 |
gimme help niiigggggaz
hey guys,
i have a 16v 4ag corolla gts converted. ive got the car running and idling decently...it still bumps around 800-1200 rpms occasionally because i need to time the dizzy and tinker with the TPS. so, the car idles fine. here's the problem: the car WILL NOT rev. it's like my AFM is completely not there, but it is...or its like i have a gigantron vacuum leak, but i dont. when i tap the throttle, itll just blip to about 3,500 ish, then go back to idle...even if im holding down the throttle. here's some background: KA24DE fuel pump & new fuel filter SR5 gas tank w/ replaced lines starts up awesome no check engine light when the car is on full coolant...small leak on the coolant inlet in the throttlebody because i ran out of clamps blocked EGR and im out of things to tell you. gimme some suggestions |
#2 (permalink) |
Car:
: 133866298 |
mine did the same thing when my fuel pump went bad. i could start it it would run, idle funny(which it allways has) but then when i would give it gas, nothing, it would wanna bog down, u know.
no vac leak around the pluged egr? good luck with the problem! |
#3 (permalink) |
brotary
Car: death machine
WC/LOL
: 140171300 |
i highly doubt there's a vac leak by the blocked egr...copper sprayed, replacement gasket, and jbweld x 20...but im AzN, so i donno
and the fuel pump...ive tested it out of the car and in the car. it shoots out a healthy stream of fuel. off topic, how is your corolla doing? |
#4 (permalink) | |
Car:
: 133866298 |
Quote:
![]() and shit, if its not hte fuel pump them in outta idea's, sryy :[ and my cars ehhh. its ok, getin a tad bit rusty up here, but def geting some nice goodies for the northern abuse i put her through. thanks for asking btw! good luck sry i couldnt help. |
#6 (permalink) |
brotary
Car: death machine
WC/LOL
: 140171300 |
nope, i havent checked the psi yet. ill pick up a gauge and check it out, but other suggestions are still welcomed.
and the lines definately arent clogged because i tested the pump in the tank and it shot out of my engine bay via supply line. just throwing it out there |
#13 (permalink) |
GREAT JOB!
Car: Truck: Bike: Penis:
727/813
: 2147483647 |
take pics of the throttle body area, around the filter and below to the right of the throttle body.
| Sponsored Links |
