+ Reply to Thread
Results 1 to 7 of 7
Thread: 240sx bible
  1. #1
    Will Drift For Tires 170k240 has a reputation beyond repute 170k240 has a reputation beyond repute 170k240 has a reputation beyond repute 170k240 has a reputation beyond repute 170k240 has a reputation beyond repute 170k240 has a reputation beyond repute 170k240 has a reputation beyond repute 170k240 has a reputation beyond repute 170k240 has a reputation beyond repute 170k240 has a reputation beyond repute 170k240 has a reputation beyond repute 170k240's Avatar
    Join Date
    Dec 2005
    Location
    tallahassee / npr
    Posts
    4,047
    Feedback Score
    9 (100%)
    240sx bible
    Alright well there is a lot of useful information out there on the internet. Unfortunately a lot of it is scattered all over the place. This is my attempt to try and bring everything to one place. I have separated them into categories to the best of my ability in the time i have heh which is not a lot. Well here it is the 240SX Bible Volume 1 which consists of a collection of DIYs, How Tos, FAQs, Install Guides, and General Info...
    Electronics/ECU
    ECU pinout diagrams.
    REWIRING YOUR IGNITION COIL
    Distributor Timing
    Removing speed limiter on 93 KA24DET
    DIY Ignition Mods for Better Spark
    Sr20det Ecu Fault Codes
    SR20DET ECU wiring diagram.
    FAQ: KA ECU # Glossory
    A long tutorial for tuning nissan's ECUs
    How-To: Chip Your ECU with Pictures (KA24E)
    Desoldering tips
    Battery Relocation
    Engine/Engine Info
    SETTING THE BASE TIMING ON THE DOHC PROPERLY
    How to build a KA24DE
    How to: S13 Oil pan removal
    DIY: HOW TO REPLACE YOUR DRIVE BELTS ON S13 / 91-93 240SX SE / KA24DE
    How-to: Build Your Own Oil Cooler
    S13 Red Top Vs. S13 Black Top - The differences
    DOHC Turbo For Dummies
    240sx Engine Descriptions
    240SX How To: Removing/Replacing your PS pump
    DIY: ITB's for your KA24DE
    Basics of engine management
    SR20DET Installation Guide
    1993 240sx Capacities and Specifications
    HOW-TO: Fix Your Timing Chain Rattle
    KA24e to KA24de swap - Step-by-step.
    240sx (S14) HotShot header install
    Does my 240sx have a bad O2 sensor?
    240sx knock sensor replacement
    How to do a compression test on your engine
    RB25DET into S13 Installation
    Engine Knock (Detonation) Sensor Replacement (KA24DE)
    Transmission
    How To: Convert from A/T to M/T
    How to Swap Your Auto Transmission for a 5-speed
    Changing transmission fluid / oil on s13
    How to install paddle shift on an automatic 240SX
    240sx Clutch and Flywheel Swap
    S14 auto -> manual with pics
    Clutch Swap
    Fuel/Nitrous
    REWIRING YOUR WALBRO 255 FUEL PUMP ON S14's
    240sx: Installing a Walbro Fuel Pump
    240sx: Replacing Your KA24DE Fuel Injectors
    DIY: Installing an injector resistor box
    Nitrous Oxide FAQ
    Turbo
    HOW TO NEVER OVERBOOST AGAIN
    Bobby's DIY turbo oil feed/return lines install
    Turbo rebuild DIY
    Turbocharging your automatic-trans car
    Suspension/Differential/Brakes
    Changing differential oil/fluid, 92 240sx, synthetic gear oil, open differential
    The Definitive 300ZX Brake Swap!
    Advanced Suspension Definitions
    Rear differential swaps for the 240sx
    Rexbo’s Guide to the s13 to s14 Front 5-Lug Conversion
    Rexbo's Guide To Brake Caliper Rebuilding
    240sx curb weights
    All you ever wanted to know about differentials
    Upgrading to J30 Brakes
    ABS Removal
    Interior
    Removing the S13 Door Panel Fabric
    Low-budget seat modification for S13
    Re-covering Your S13 Glove Box
    DIY: Window regulator repair 5$
    DIY: Dye That Ugly Carpet!!!!! W/pics
    Water leaking into trunk (240sx fastback)
    Camera Mount
    Exterior
    HOW TO: Repaint Headlight Housing (Black)
    DIY: Replacing Your Rusted Hatch
    240sx Conversions - An Introduction
    Sleepy Eyes walkthru (VID)
    240sx Vented Hood DIY
    Rust removal, Fiberglassing, and Body Filler
    DIY: Silvia Foglight Wiring
    All-red S13 Taillights
    Restoring your Nissan's paint
    240sx power antenna repair
    Article: General car cleaning/detailing tips
    Factory Service Manuals/Diagrams
    Factory Service Manuals (FSMs)
    Your home for factory service manuals
    Parts Lists / Diagrams / Setting Sheets
    HowStuffWorks Articles
    How Manual Transmissions Work
    How Differentials Work
    How Turbochargers Work
    What is the difference between a turbocharger and a supercharger on a car's engine?
    How Car Engines Work
    How Clutches Work
    How Car Computers Work
    How Fuel Injection Systems Work
    How Car Suspensions Work
    How Anti-Lock Brakes Work
    How Master Cylinders and Combination Valves Work
    What does it mean when a car has dual overhead cams?
    How Camshafts Work
    from Tomek @ Ka-t.org
    S14 parts, aftermarket and stock, holset turbo, injectors, oem parts, ka's, etc. for sale
    Mechanical Engineering, Florida State University
    this is my track car build
  2. #2
    Registered User Kung. has a reputation beyond repute Kung. has a reputation beyond repute Kung. has a reputation beyond repute Kung. has a reputation beyond repute Kung. has a reputation beyond repute Kung. has a reputation beyond repute Kung. has a reputation beyond repute Kung. has a reputation beyond repute Kung. has a reputation beyond repute Kung. has a reputation beyond repute Kung. has a reputation beyond repute Kung.'s Avatar
    Join Date
    Sep 2007
    Posts
    8,668
    Feedback Score
    4 (83%)
    I love this thread. <3
  3. #3
    1 wheel all the way jds95sx has a reputation beyond repute jds95sx has a reputation beyond repute jds95sx has a reputation beyond repute jds95sx has a reputation beyond repute jds95sx has a reputation beyond repute jds95sx has a reputation beyond repute jds95sx has a reputation beyond repute jds95sx has a reputation beyond repute jds95sx has a reputation beyond repute jds95sx has a reputation beyond repute jds95sx has a reputation beyond repute jds95sx's Avatar
    Join Date
    Sep 2008
    Posts
    928
    Feedback Score
    1 (100%)
    ifu dont know half this shit sell ur car and get a mini van
  4. #4
    EF your self davidf has a reputation beyond repute davidf has a reputation beyond repute davidf has a reputation beyond repute davidf has a reputation beyond repute davidf has a reputation beyond repute davidf has a reputation beyond repute davidf has a reputation beyond repute davidf has a reputation beyond repute davidf has a reputation beyond repute davidf has a reputation beyond repute davidf has a reputation beyond repute davidf's Avatar
    Join Date
    Mar 2009
    Posts
    370
    Feedback Score
    4 (100%)
    So what mini van would you recommend ?
    LOL jk.
  5. #5
    FCP xjrider95 has a reputation beyond repute xjrider95 has a reputation beyond repute xjrider95 has a reputation beyond repute xjrider95 has a reputation beyond repute xjrider95 has a reputation beyond repute xjrider95 has a reputation beyond repute xjrider95 has a reputation beyond repute xjrider95 has a reputation beyond repute xjrider95 has a reputation beyond repute xjrider95 has a reputation beyond repute xjrider95 has a reputation beyond repute xjrider95's Avatar
    Join Date
    Oct 2008
    Location
    Palm Harbor
    Posts
    1,484
    Feedback Score
    10 (100%)
    Quote Originally Posted by davidf View Post
    LOL jk.
    i would make sure its at least rwd
    Just throwing it out there, by the looks o your car you can make anything work on it.
    1983 AE71 Corolla- 16v 4age... racecar
    1993 D21 Hardbody- a/c, music... grocery getter
    - Garrison -
  6. #6
    Registered User R_H SX is an unknown quantity at this point
    Join Date
    May 2010
    Location
    Welsey Chapel, Fl
    Posts
    Feedback Score
    hi im rob i had a quick ? wound u have a timing chain cover for sale
  7. #7
    Registered User mex08 has a reputation beyond repute mex08 has a reputation beyond repute mex08 has a reputation beyond repute mex08 has a reputation beyond repute mex08 has a reputation beyond repute mex08 has a reputation beyond repute mex08 has a reputation beyond repute mex08 has a reputation beyond repute mex08 has a reputation beyond repute mex08 has a reputation beyond repute mex08 has a reputation beyond repute mex08's Avatar
    Join Date
    Jun 2009
    Posts
    308
    Feedback Score
    thats a right click and save lol
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201
