Forums Register TRHelp TRGarage TRader Ratings Classifieds Search Today's Posts Mark Forums Read Calendar
iTrader Mainpage
Browse All Members
FAQ Gallery Weather Log Out
Go Back   Tampa Racing > Motorsports & General Tech > Drifting > Drifting Tech
Old 07-09-2006, 10:39 PM   #1 (permalink)
REY
Registered Banana
Car: 85 AE86 GTS Hatchback
REY has a reputation beyond repute: 62514179
Power Window Problemo
The other day, I went to roll the window down to drop a quater in the toll receptable when it refused to go down. I pressed the window lock button down then up again but still nothing. When i got home, i pressed the window button and it worked... I was like WTF?.. ever since then, the windows worked fine, until yesterday when i was on my way to HIN and it began to rain and it refused to go up. Neither window operates. I can hear the relays clicking but nothing happens.. Any Ideas????
- Rey
REY is offline
Old 07-09-2006, 11:19 PM   #2 (permalink)
AAAAAAaaaaYYYYYEEEEEEEE!!
Car: infamous "T2"
its quick, u aint kno
Anthony R has a reputation beyond repute: 112630245
have u taken the door panel off yet? i took mine off and it has that lil' balck rectangle thingy, maybe the relay. i hear it click but nothing. i replaced it and now it works.
Anthony R is offline
Old 07-09-2006, 11:21 PM   #3 (permalink)
sr20 ahahahahahaha
Car: 1995 nissan ka-titties
tallahassee / npr
170k240 has a reputation beyond repute: 152528624
is it the normal 240 driver side switch malfunction? where if you wiggle the switch and it works? because thats what mine does...
170k240 is offline
Old 07-10-2006, 09:08 AM   #4 (permalink)
Car: 93 s13 coupe
Port Richey
ph0tek has a reputation beyond repute: 29547343
Rey, ive been through this 5 times now.
Its the lil box that the power window switch is plugged into.
If you take it off the door and slide out the board inside you will see that a connector is burnt around the solder point. If you put a dab (very small) back on it it should fix it until the next time it decides to burn out, alot of times if you wiggle it, it will arc enough to make connection and work, (hence the work sometimes and not the other)
Believe me its a pain in the ass, and those lil fuckers are hard to find.
Good luck and I will keep my eye out for one for ya. =)
ph0tek is offline
Old 07-12-2006, 06:12 PM   #5 (permalink)
REY
Registered Banana
^^ thank you ... problemo solved...
REY is offline
Sponsored Links
