#2 (permalink) |
Car: 93 s13 coupe
Port Richey
: 29547343 |
too much roll.
Youll be clunking the front end during switchback. Get coils. Call it a day. If you drift once a month, go for springs and shox, if your a weekend warrior get coils. If you drift twice a week, youd already have coils. =) |
#4 (permalink) |
Car: 93 s13 coupe
Port Richey
: 29547343 |
www.jdmmarket.com
Call down to cfp and see if Ivans got some laying around Im sure he does. Well worht the money. If you simply dont want coils. Tokico Blues, and Eibach Prolines. Replace every bushing you can. Get inner/outer tie rod ends with spacer, and get a good alignment. Weld the diff (cause obviously cash flow is a henderance) and go out sliding. |
#6 (permalink) |
Car: 93 s13 coupe
Port Richey
: 29547343 |
the cuscos are good, not sure of the backing they have in the US, someone else might know offhand how their stateside support is, along with the JIC's....
Read up on them and do some research, (which I know you are trying to do by asking here) but be pro-active in your search for information and it will yield better results, and faster reseults. I have no knowledgebase and wouldn't want to mis-inform you. |
#11 (permalink) |
its CRACK bitch!
Car: your mom
Carrollhood
: 900 |
HP (blues) are for a "sport" spring only! if you go with a more aggresive spring on the HP's they will blow...if you want tokico buy the luminas(sp)
AGX's are better but there only good with a spring that lowers a car up to 1.75inches anything more will blow and void the factory waranty... i know this b/c i did it... |
#15 (permalink) |
Wanna make bunk beds?
Car: 1999 Jeep Wrangler
Ft. Bragg, CA
: 851725389 |
megans are around $850 new
| Sponsored Links |
