#2 (permalink) |
Grandpa
Car: 1970 Dodge Challenger RT 2005 Hemi Chrysler 300C 1999 GMC Sierra
Pinellas Park
: 10915645 |
The seat belt reminder system uses both visual and audible signals. A combined seat belt and key reminder chime with a red light on the instrument panel.
The system will always illuminate the seat belt reminder lamp for four to eight seconds when the ignition switch is turned to the ON position. The CHIME will sound during the same time interval if the driver's seat belt is not fastened. Passenger belts are not connected to the system. The chime will activate if the drivers door is opened and:
CLUSTER WIRING - HARNESS CONNECTORS J1 CONNECTOR J2 CONNECTOR PIN DESCRIPTION PIN DESCRIPTION 1 DOOR AJAR 1 OIL PRESSURE 2 HI BEAM 2 ABS 3 RIGHT TURN 3 MIL * (SERVICE ENGINE SOON) 4 SEAT BELT 4 ENGINE TEMPERATURE 5 IGNITION FEED 5 KEY IN / HEADLAMPS ON 6 BATTERY 6 BRAKE 7 TACHOMETER SIGNAL 7 CHARGING SYSTEM 8 GROUND 8 LEFT TURN 9 AIRBAG 9 ILLUMINATION 10 SPEED SIGNAL 10 FUEL LEVEL |
#3 (permalink) |
727
Car: dodge neon 2.0l dohc
H-town
: 10 |
thank you for tht but i just took the pin out on the door jamb and disconnected it much better no headache and i still have dome lamp
| Sponsored Links |
