#1 (permalink) |
TR Balla Donor Supreme
Car:
Brandon/Chicago/VA
: 2147483647 |
Mod. Pefromance turbo kits?
Hahn Racecraft Turbo systems for 1995-1999 Dodge / Plymouth Neons
ok so i was looking at this turbo kit for a little down the road and it looks like its got basicly everything i'd need to do it, anyone see anything missing Super 16g Mitsubishi turbo (This turbo is highly known in the DSM communities for its efficiency, and fast spool up times and reliability.) Cast Stainless Steel Exhaust Manifold Ceramic coated, mandrel bent 2 1/4 Down Pipe Single pipe, stepped design from 2" to 2 1/4"air piping. Standard, OE 3000 GT Blow off valve Fuel pressure gauge for tuning of system Fuel pump regulator hoses fittings lines electronic mods K&N w/ mandrel bent piping thats exactly wat it has on the page. anything missing other than IC? |
#10 (permalink) |
Out Of Towner
Car: A couple Neons.
Summerville, SC
: 649782161 |
Well the srt turbo and mani are one peice but once you get your entire srt turbo setup on your car you'll be inlove with it. When you get used to that power you can just get another manifold and a different turbo and that's it. Just a quick/inexpensive way to go turbo.
#12 (permalink) |
Car: highline neon, acr neon, cbr 900rr, xr100r dirtbike, 04 altima 2.5S, 05 kawi 636
Holiday
: 173969605 |
if you have the money go for the hann kit, you can do the srt kit for around 1,200(ive pieced it together in the past) but if you want to go bigger and bigger youll end up replacing mos of the parts with better ones and in the end you may spend more than the hann kit is alone. trust me i pieced together a full turbo kit and if you have time and knowledge its possible but still a pain an takes a while. its much easier to just buy the kit which has everything included
#14 (permalink) |
Holiday
: 173969605 |
that would be the best way, plus the hann kit is made specific for the car and when installed it is clean and not a bunch of used pieced together parts to make due. ive heard hann is good quality and there are many neons running that kit out there.
#15 (permalink) | |
Car:
Brandon/Chicago/VA
: 2147483647 |
Quote:
well most the stuff modern. perf. sells in high quality from what i can see, but now alls i need is the 3.5k lol |
| Sponsored Links |
