+ Reply to Thread
Results 16 to 25 of 25
07-01-2009 01:50 PM #16Registered User
- Join Date
- Jul 2009
- Posts
- 1
- Feedback Score
- 0
07-07-2009 10:41 PM #17Registered User
- Join Date
- Jul 2009
- Posts
- 2
- Feedback Score
- 0
Timing belt tensioner
Quick question for those of you that have replaced the timing belts. Do you replace the tensioner too? I nearly had my wife's PT put back together when I was told that I should have replaced the tensioner at the same time due to the failure rate of the type 1 tensioner that was originally put on. Apparently I should have replaced that with the new type. Does the old type have a high failure rate? So I've stopped at about 90% put back together and wondering if I need to tear it apart again.
Thanks,
07-07-2009 11:34 PM #18
I replace everyone I do, no matter the car, just good insurance
07-08-2009 11:26 PM #19Registered User
- Join Date
- Jul 2009
- Posts
- 2
- Feedback Score
- 0
Thanks for the reply. I'm going to go ahead and replace the tensioner and have some peace of mind. At least I wasn't completely done with the job, next time I'll know...
Thanks again,
09-25-2009 09:59 PM #20Registered User
- Join Date
- Sep 2009
- Posts
- 1
- Feedback Score
- 0
Hi, my 2003 PT Cruiser just stopped in the middle of the street last week and was towed to a local mechanic. The problem was the timing belt which they replaced, along with my powering steering and alternator belts while the engine was apart. Now I have no A/C. I have 143,000+ miles on the car and the A/C was replaced approximately 50,000 miles ago and has been cranking wonderful cold air. Now the mechanic is not accepting blame for the broken A/C and even charged me for freon because they had to drain it when they moved parts of the A/C to replace my belts. They insist that it was low on freon to begin with so they had to top it off.
I brought the car back this morning to complain about the lack of A/C. They are now claiming that I have a leak and want to charge me to fix it. They claim they had nothing to do with my current problem and that they can tell by a colorful fluid that they put in the system to show possible leaks. All I know is that I had great A/C when the timing belt died and now have none. I am at a loss as to what to do at this point.
Thank you, in advance, for any help or suggestions you can give me.
10-26-2009 01:00 PM #21Registered User
- Join Date
- Oct 2009
- Posts
- 1
- Feedback Score
- 0
03-05-2010 08:13 PM #22Registered User
- Join Date
- Mar 2010
- Posts
- 1
- Feedback Score
- 0
I can't get the main pulley off the engine.
I removed all the bolts from the power steering pump bracket that are on the timing belt side of the engine and it still won't come off. Did I miss a bolt somehwere else?? I took off the ones I could fine, yes the ones in the holes to and the one on the bottom of the bracket from underneath.
What the hell. I need to get to work and the repair manuals are vague and crappy.
Anyone have some tips or pictures??
Thanks a bunch for any help.
03-08-2010 12:27 PM #23Race Photographer
- Join Date
- Nov 2000
- Posts
- 43,534
- Feedback Score
- 6 (100%)
yout trying to get the crank pulley off? you need a balancer puller. it takes a special one not a normal one
03-18-2010 01:39 AM #24Registered User
- Join Date
- Mar 2010
- Posts
- 1
- Feedback Score
- 0
Right motor mount
The instructions don't say anything about disconnecting the transaxle from the left mount so you can move the engine away from the right mount. This is the only way I could get the right mounting plate away far enough to get to the timing belt/water pump, ect...
11-26-2011 01:29 PM #25Registered User
- Join Date
- Nov 2011
- Posts
- 1
- Feedback Score
- 0
DEMON CIVIC: I would like to discuss your offer of fixing the water pump/timing belt on my PT Cruiser (2002) Please email me with phone number and business name so I can call you. Thank you.
tom_tagliente19@yahoo.com
Tom
Thread Information
Users Browsing this Thread
There are currently 2 users browsing this thread. (0 members and 2 guests)
LinkBack URL
About LinkBacks
