info on a shadow
iam buyin a early 90's dodge shadow, new to dodge so i was wonderin if any body knew and info in them. its turbo so let me know if theres any after market stuff for it, and just general info on the car
thanks,
steven
thanks,
steven
Cornbread Crew member #754
theres a ton of stuff to do to them... there almost the same as my car....check out fwdperformance.com or forward motion inc.....thats were i get all my parts from....best thing is there cheap but is good quality stuff....there mad easy to fix btw....idk about the early 90 but i know the 80s models has its own diagnosis check on the cars u just need the book to tell u what the codes mean....hope this helps hit me up if u wanna know or need any help with anything
._________________________
|.....Overnight.....................| ||
|........Japan Parts................||'|";,___. <~~~~~~~~~~~~~ \_ OH NO'S! It's Toretto!
|_..._...____________======||_|_|...,]------------------__/----\___
"(@)'(@)""'''''''''''''"'''"**|(@)(@)*****"(@)--------------~['(@)***(@)_'\
also how much boost can you push out of the stock turbo???and what is stock boost on these cars??
i know stock on mine is 7lbs.....but its undergoin some changes lol....thanks to those 2 sites..... oh! check out thedodgegarage.com u can learn everything u need to know there
well i got the shadow today...its ok does anyone have any input as to waht i should do first to the motor??its a 1990,5 speed,single cam....i am new to dodge so any help would be uesful
thanks,
steven
thanks,
steven
thanks,
steven
thanks,
steven
Intercooler it. Turn the boost up. Get a little shot of nitrous. get slicks. Take some weight out, and it should be capable of 12's.
Easy to work on ? Yea... maybe the spart plugs... EVERYONE OF THESE CARS IN THE BONE YARD HAVE THE TURBO STILL ON IT, why ? IT A FUCKING NIGHTMARE TO GET TO.
Fun cars though. VERY STRONG bottom-end. Cylinder head flow is right up there with the best head designs EVER, like the ford 2.3 and ford 5.0
86' snapper electric powered lawn mower.
95' F-350 crew-cab powerstroke 5-speed 21.63mpg
03' G35 6-speed coupe. Grey on black.
02' wranlger apex edition with EFI 5.0L 302 SBF. 5.5'' lift, custom 4-link 8.8 in the rear, high pinion D30 front with locker.
A wise man once said, " I didn't wash my hands b/c my D**K is cleaner then ANYTHING, in that bathroom"
Originally Posted by ttawd3s
Ask Tim with the turbo'd PT a million questions, and then ask him to show you the 20 minute head gasket trick about 5 minutes after you turn the boost up, hehe.
Here's a crude example that i ran in my Shadow.
Remove some weight,intercool it, drop in a set of 52lb injectors(or 2 cold start injectors running off hobb switches), a diode to fool the map, a set of slicks, switch over to a stock Garrett turbo as the Mitsu is very small, crank up the boost to 22-25 psi(watch for detonation)
And you will run 12's if the clutch holds up
my 2.2 liter Shadow ran in many TR events, ran 12's with the 5 speed since my auto tranny blew up, if i still had the auto i would have been knocking on 11's
what cars came with a garrett turbo stock??
Check here to see the GLH-T omni and the stckness monster with the sticker still in it.
