Forums Register TRHelp TRGarage TRader Ratings Classifieds Search Today's Posts Mark Forums Read Calendar
iTrader Mainpage
Browse All Members
FAQ Gallery Weather Log Out
Go Back   Tampa Racing > Technical Forums > Dodge Tech
Old 02-22-2006, 01:29 PM   #1 (permalink)
Car: highline neon, acr neon, cbr 900rr, xr100r dirtbike, 04 altima 2.5S, 05 kawi 636
Holiday
neondriver has a reputation beyond repute: 173969605
stalling
so my car constantly stalls at idle. after it warms up it can sit and idle. but when driving it once i go into neutral for a red light or even in traffic it will stall out unless i give it a little extra gas to keep the rpm's over 1k, and suggestions on why it keeps stalling. some say it is because of the cams.
neondriver is offline
Old 02-22-2006, 04:50 PM   #2 (permalink)
Grandpa
Car: 1970 Dodge Challenger RT 2005 Hemi Chrysler 300C 1999 GMC Sierra
Pinellas Park
Dano Moparo has a reputation beyond repute: 10915645
AIS, TPS, PCM, coil, plugs, wires, gummy throttle body
or all of thee above
Dano Moparo is offline
Old 02-22-2006, 05:29 PM   #3 (permalink)
Peon on steroids!
Car: 97 Dodge neon coupe(built SRT engine when I have the time) '66 mustang coupe(restomod project)
Franklin, TN
Josiah is an unknown quantity at this point: 100
ISC would be my first guess, but like dano said, any of the above "can" cause it
Josiah is offline
Old 02-22-2006, 07:53 PM   #4 (permalink)
Car: 1998 sohc mtx neon
Valrico
Valrico31 is an unknown quantity at this point: 199
i am currently having the same problem in my neon. On start up, it is idling at around 600 rpm and then stalls. When it warmed up, it'll idle maybe 800 rpm. Cleaned the IAC and tb with no luck there.
Valrico31 is offline
Old 02-22-2006, 10:54 PM   #5 (permalink)
Holiday
well i guess the car was in a good mood tonight because it didnt stall once. im probally going to do a full tune up on it this weekend and see if that helps. also originally the car had the breather on the head cover plugged(one that went from the cover to the intake pipe) maby its a small vac problem....seems like ill have some investigating to do this weekend
Old 02-23-2006, 12:23 AM   #6 (permalink)
Grandpa
Pinellas Park
I wouldn't rule out the fuel pump either. But those vacuum lines are a good start. Be careful and spray some carb cleaner or something on the lines, and around the thottle body and see if the idle picks up.
If you don't want a mess, take a unlit propane torch, crack it open a little and point it around the lines, TB and intake where they mate. Sould have same results.
Old 02-23-2006, 05:21 PM   #7 (permalink)
Peon on steroids!
Franklin, TN
if anything a vacuum leak will generally cause your car to idle at a higher speed, not a lower one, try this, you have 2 plugs on your TB, the TPS and the ISC, on a DOHC neon the TPS sensor connector sits pointing toward the passenger side of the car, while the ISC is on the back side of the TB(back side being the side closest to the head) unplug your ISC, your car should immediatly idle at 3000RPM if it is working correctly, if it takes longer than 10 seconds for it to reach the high idle speed, I would replace the ISC
Josiah is offline
Sponsored Links
