#2 (permalink) |
Car: highline neon, acr neon, cbr 900rr, xr100r dirtbike, 04 altima 2.5S, 05 kawi 636
Holiday
: 173969605 |
yes, josiah did it and i bought his manifold.alot of people do it.heres mine
![]() i also like this one his build is found HERE Last edited by neondriver : 10-06-2005 at 08:15 PM. |
#3 (permalink) |
Peon on steroids!
Car: 97 Dodge neon coupe(built SRT engine when I have the time) '66 mustang coupe(restomod project)
Franklin, TN
: 100 |
oh, wanted to thank you btw man, I relocated my battery to the trunk with an amp kit...worked great from what I can see, glad that manifold is working for you...was a huge PITA for some reason, speaking of which...do a 5 speed swap...I will personally kick your atx tranny...he he, my SRT swap is almost running...just misc EDIS4 and MS stuff holding me back now...think I'm going to have to rewire my engine bay...again, going to make a harness from scratch this time and eliminate the stock computer completely, now as far as cutting the 90 out...I highly reccomend it for many different reasons...but be prepared to lose your ISC unless you do more modifying than I had the heart to to keep the worthless thing
#4 (permalink) |
Car: 98 neon RT,03 GT V6 tiburon,95 GS-T
: -101 |
ok cool, do they just take the flange off cut out the elbow and weld the flange onto it straight? and are there beifits to doing this? also where did you relocate the metal piece in the elbow that is for those two vacum lines? oh yeah one more thing can a 60mm throttle body still work in this set up(i mean will there be enough room at the intake entrance to be ported to 60mm)?
#5 (permalink) | |
Holiday
: 173969605 |
Quote:
#6 (permalink) | |
Holiday
: 173969605 |
Quote:
#8 (permalink) | |
Holiday
: 173969605 |
Quote:
for ex. this is an srt mani ![]() here is another custom one ![]() on a 2.4 Last edited by neondriver : 10-07-2005 at 12:39 AM. |
#10 (permalink) |
: -101 |
ok yeah im pnp the manifold if i can get someone to weld it for cheap enough i will do it, it should get me a couple, also with the egr im buying an afx comp. i believe it bypasses that sensor so no check light. thanks for the info
#11 (permalink) |
Peon on steroids!
Franklin, TN
: 100 |
cost me about $40 to have it welded...but thats because I dont know anyone who can weld aluminum...otherwise it would be cheaper not having to pay a shop's prices, I did the cutting and tapping myself though
#14 (permalink) | |
Holiday
: 173969605 |
Quote:
#15 (permalink) | |
: -101 |
Quote:
| Sponsored Links |
