Forums Register TRHelp TRGarage TRader Ratings Classifieds Search Today's Posts Mark Forums Read Calendar
iTrader Mainpage
Browse All Members
FAQ Gallery Weather Log Out
Go Back   Tampa Racing > Technical Forums > Dodge Tech
Old 09-30-2005, 08:59 PM   #1 (permalink)
The lost pony
Car: 88 merkur xr4ti 77 must ll
SPRING HILL FL.
barry bledsoe has a reputation beyond repute: 504948120
neon fan wont shut off
97 neon and the cooling fans keep running I have looked for relays and cant find them. does anyone know what my problem is or know where the relays or temp sensor is any info would help thanks
barry bledsoe is offline
Old 09-30-2005, 10:31 PM   #2 (permalink)
The lost pony
SPRING HILL FL.
I just tried the temp sending unit that was not it
Old 09-30-2005, 10:38 PM   #3 (permalink)
Grandpa
Car: 1970 Dodge Challenger RT 2005 Hemi Chrysler 300C 1999 GMC Sierra
Pinellas Park
Dano Moparo has a reputation beyond repute: 10915645
There's a fan relay/module thats bad. pn 4704286af costs about $70 at the dealer.
Dano Moparo is offline
Old 09-30-2005, 10:44 PM   #4 (permalink)
Grandpa
Pinellas Park
SUBJECT: Vehicle Overheats (Radiator Fan Inoperative) Or Radiator Fan Runs Continuously
DATE: Apr. 17, 1998
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 07-07-97 DATED FEBRUARY 20,1998 WHICH SHOULD BE NOTED IN THE 1997 TECHNICAL SERVICE BULLETIN MANUAL (PUBLICATION NUMBER 81-699-98004). THE REVISION PROVIDES A NEW PART NUMBER FOR THE RADIATOR FAN RELAY. THE CHANGE IS HIGHLIGHTED WITH ASTERISKS.
NOTE: THIS BULLETIN APPLIES TO VEHICLES BUILT AT TOLUCA ASSEMBLY PRIOR TO SEPTEMBER 11, 1997 (MDH 0911XX). TOLUCA ASSEMBLY IS DESIGNATED BY A "T" IN THE ELEVENTH POSITION OF THE VEHICLE IDENTIFICATION NUMBER.
SYMPTOM/CONDITION:
Vehicle overheats or radiator fan continues to run.
DIAGNOSIS:
Actuate the radiator fan relay using the DRB III. If the radiator fan does not come on or fan runs continuously, perform the Repair Procedure.
PARTS REQUIRED:
QtyPart No.Description105293157AAJumper Wire With Diode , Radiator Fan**104707286Relay, Radiator Fan**206015756Tie Strap
REPAIR PROCEDURE:
This bulletin involves installing a radiator fan jumper wire assembly into the headlamp and dash wiring harness, and replacing the solid state relay.
  1. Raise the hood and disconnect the negative battery cable.
  2. Raise the vehicle on a suitable hoist.
  3. Locate the left (driver’s side) black fan motor connector. Retract the red latch on the two-way female connector, depress the thumb latch, and disconnect the connector from the fan (Figure 1). If the wiring to the fan motor is clipped into the fan support, gently pry it out of the hole so the fanis not damaged.
  4. Pry out the two christmas tree type retainers located on the lower radiator enclosure reinforcement.
  5. Install the jumper wire assembly (p/n 05293157AA) between the radiator fan and the headlamp and dash harness:
    1. Attach the black two-way male connector with the clip into the outboard hole, so the connector faces outboard toward the left side of the vehicle. Attach the second clip into the inboard hole of the lower reinforcement that the original wiring came out of (Figure 2).
    2. Connect the original two-way black connector to the new mating connector installed in the previous step and slide the red latch into the locked position.
  6. Connect the two-way female black connector on the new jumper assembly to the fan connector and slide the red latch into the locked position. If the original wiring to the fan was clipped into the fan support, snap the new clip on the jumper into the same hole.
  7. Bundle the excess original fan wiring and tie strap to the main bundle of vehicle wiring in the front left corner in two places. NOTE: ENSURE THAT THE WIRING BUNDLE IS SECURE AND DOES NOT INTERFERE WITH ANY OTHER COMPONENTS.
  8. The solid state fan relay is located on the left front rail. Retract the red latch on the black four-way connector and disconnect from the solid state fan relay.
  9. Remove the two screws that secure the relay to the side of the left front rail and remove the relay.
  10. Install the new solid state fan relay ** (p/n 04707286)** and locate the index pin on the relay into the locator hole in the rail. Secure with the two screws and torque to 5 N•m (45 in.lbs.).
  11. Connect the four way connector and slide the red latch into the locked position.
  12. Lower the vehicle and connect the negative battery cable.
POLICY:
Old 10-02-2005, 09:25 PM   #5 (permalink)
Skittle on crack!
Car:
Somewhere
cali has a reputation beyond repute: 15280620
That sounds like a freak ish fix....why wouldnt design a direct replacement relay?
cali is offline
Sponsored Links
