Forums Register TRHelp TRGarage TRader Ratings Classifieds Search Today's Posts Mark Forums Read Calendar
iTrader Mainpage
Browse All Members
FAQ Gallery Weather Log Out
Go Back   Tampa Racing > Technical Forums > Dodge Tech
Old 08-21-2005, 01:01 AM   #1 (permalink)
Car: 1986 Dodge Daytona Turbo Z
Wesley Chapel
ToyotaMRK88 is an unknown quantity at this point: 10
Daytona Losing Volts
After changing the alternator and the battery my car still wont hold the charge. some said it was the voltage regulator but i looked and it doesnt look like that car has one. than someone told me its the Power Control Module. What do i need to do?
ToyotaMRK88 is offline
Old 08-21-2005, 02:24 AM   #2 (permalink)
Grandpa
Car: 1970 Dodge Challenger RT 2005 Hemi Chrysler 300C 1999 GMC Sierra
Pinellas Park
Dano Moparo has a reputation beyond repute: 10915645
yes the voltage regulator is part of control module. You need to replace the module, no parts are serviced for it.
Dano Moparo is offline
Old 08-21-2005, 02:51 PM   #3 (permalink)
Wesley Chapel
Where is the Computer
where is the computer and is it hard to replace?
Old 08-21-2005, 11:14 PM   #4 (permalink)
Wesley Chapel
what kind of exaust should i get? straight pipes, flowmaster, or ricer exhaust
Old 08-21-2005, 11:54 PM   #5 (permalink)
Sales Rockstar
Car: Dodge 2500 CTD, FLHX Of Doom, CRF250R
Palm Harbor
HMCK20 has a reputation beyond repute: 232282593
your daytona is turbo right? 3" straight back or dump out the side if you can.if its NA then get a greddy or or something if they make a kit for that car.
HMCK20 is offline
Old 08-22-2005, 10:30 AM   #6 (permalink)
Grandpa
Pinellas Park
The computer on that is called a "power module" its located in the right front behind the battery. Its a fairly large black plastic item with large holes at either end for the fresh air to run thru it.
Old 08-22-2005, 05:54 PM   #7 (permalink)
Skittle on crack!
Car:
Somewhere
cali has a reputation beyond repute: 15280620
What kind of V do you have with the car '0N' and running?
cali is offline
Old 08-22-2005, 10:50 PM   #8 (permalink)
Wesley Chapel
with a fully charged battery it will be at 12 or 13 volts. after it runs for about 10 minutes it will drop to 8 volts
Old 08-23-2005, 06:53 PM   #9 (permalink)
Skittle on crack!
Car:
Somewhere
I find that strange that just idling or running will drain your battery so fast. Is the battery 'good'?
I assume the car dies if you disconnect the battery after starting it?
You'll want to verify the wires going to the alternator are good. Esp the ground.
Usually there is a wire to the PCM that controls the magnetic field on the alternator ( this determines how much "V" the alternator will oputput). Check that too.
This is all under the assmption that:
Quote:
I'm no expect on that year's PCM but I'll trust the post.
cali is offline
Old 08-24-2005, 03:19 PM   #10 (permalink)
Wesley Chapel
Fixing it up
I need some more advice on what kind of exhaust to get. what kind of intercooler will fit on there. whats the biggest i could get the rims without it messing it up.
Old 08-24-2005, 03:27 PM   #11 (permalink)
Wesley Chapel
also what wires go with what switch for the power windows. and what would it take for me to make them manual windows instead of power windows
Old 08-25-2005, 04:46 PM   #12 (permalink)
Old Man With Fast Wheels
Car:
Valrico,FL
Grease is on a distinguished road: 1248
Go check out this site..
www.turbododge.com
Lot of good help there..
Grease is offline
Old 08-29-2005, 05:26 PM   #13 (permalink)
Grandpa
Pinellas Park
Quote:
all you really need to change is the regulator, that and you'll need a handle too. Prob best and go the bone yard and grab it since its long discountinued from Chrysler. Looks like they used manual as an option from 84-89 and are the same. The power set up is the same to 1993 . I can't download any wiring diagrams back that far from Chrysler so you prob should just get a service manual for the wiring.
Sponsored Links
