#3 (permalink) |
Peon on steroids!
Car: 97 Dodge neon coupe(built SRT engine when I have the time) '66 mustang coupe(restomod project)
Franklin, TN
: 100 |
street tuning is an oxy moron unless you have a standalone and a wideband, with a stock or near stock SRT4 theres not much you can adjust anyway unless you have a return line...then I suppose you can adjust fuel pressure, how can you "tune" without control of pulsewidth or at the very least fuel pressure?
#4 (permalink) |
Senior Member
Car: 1998 S10 soon to be LS1; 1998 GSX-R600
Tampa
: 153 |
Not necessarily, if you have wideband and egt monitoring capabilities (timing would be good also) you could adjust a number of things i.e.wastgate, boost controller, map clamp, etc. and have a stronger running car with quite a decent gain in hp...you don't necissarily have to have a standalone. I am datalogging with Zeitronix and making my adjustments to my MBC and Map clamp to reach my desired A/F (11.5) @WOT, no standalone here.
#5 (permalink) | |
It's a Family Car Officer
Car: '04 Red Skittle and '00 Red Grand Cherokee
Tampa
: 882030 |
Quote:
#6 (permalink) | |
Senior Member
Tampa
: 153 |
Quote:
#7 (permalink) |
GY-16P
Car: 2000 silver coupe & 2002 Lexus IS300
Spring Hill
: 46424158 |
i think hes pulling quite a bit of timing. i'm not sure tho.
Running 12 PSI it has a Garret Gt3071r ATP Turbo Manifold Prototype ATP 02 Housing Tial External Wastegate Greddy profec B Series II 3" downpipe with cat. SSQ BOV Stock FMIC |
#8 (permalink) |
Peon on steroids!
Franklin, TN
: 100 |
true...but my map clamps I always set right below cutout and never messed with them from there...they were finicky enough as was and tended to break on any excuse, I hated having to make a new one...took like 1 hour...went through 5 of the stupid things before I got pissed off and went with a standalone
#10 (permalink) | |
Senior Member
Tampa
: 153 |
Quote:
#11 (permalink) |
Got Toys?
Car: 99 Yukon,92 KX 125,96' Banshee,240sx/ls1(one day it will be done)..
Tampa
: 2147483647 |
I'm guessing he's using ATLEAST a Safc.
| Sponsored Links |
