Forums Register TRHelp TRGarage TRader Ratings Classifieds Search Today's Posts Mark Forums Read Calendar
iTrader Mainpage
Browse All Members
FAQ Gallery Weather Log Out
Go Back   Tampa Racing > Motorsports & General Tech > Chassis & Suspension Tech
Old 03-26-2008, 10:08 PM   #1 (permalink)
Turn 7 at Sebring
Car: 92 240 Coupe, 00 GLX
27°46′14″N 82°40′46″W
RoadRacer has a reputation beyond repute: 379532276
DOM tubing
Does anyone know where I can get 1.75" x .095" Seamless mild steel (DOM) tubing?
Thanks
RoadRacer is online now
Old 03-27-2008, 01:05 AM   #2 (permalink)
Car: 2001 Mustang GT
Clearwater
ChrisN1313 has a reputation beyond repute: 373475867
Quote:
Thanks
I got some from ART today but it was a tad bigger like .120 Give them a try they should have it
ChrisN1313 is offline
Old 03-27-2008, 03:02 AM   #3 (permalink)
Mechanical Engineer
Car: 2000 SS
PALM HARBOR
BLUE2KSS has a reputation beyond repute: 251077867
ART carries 4130 if you are looking for that
you might also want to check Metal Supermarkets in downtown tampa. I am going to be picking up some 1.75" .120 tomorrow actually for a jig for our axle to be heat treated
BLUE2KSS is offline
Old 03-27-2008, 07:58 AM   #4 (permalink)
Clearwater
that or Alro Metals on 49th street. They will have it for sure.
Old 03-27-2008, 10:14 AM   #5 (permalink)
Turn 7 at Sebring
Thanks for the info, I will try alro and Metal Super Market.
ART doesn't carry DOM.
If I can't find DOM, then I will probably use CroMo from ART.
Old 03-27-2008, 02:10 PM   #6 (permalink)
Clearwater
Thats funny I just bought a nice chunk of it yesterday from ART. Maybe I bought the rest of it
Old 03-27-2008, 02:29 PM   #7 (permalink)
Turn 7 at Sebring
hmm, I called earlier this week and they said they only sell ERW, not DOM.
I have an ART cage in my car right now, but the new car I am building needs DOM tubing to be legal in order to run with NASA.
I will call ART again. Thanks for the info
Old 03-29-2008, 01:41 AM   #8 (permalink)
Race Photographer
Car:
Mars_302 has a reputation beyond repute: 2147483647
how do they know the different anyway betten seam welded and drawn over mandrel especially after its all painted? You sure .095 is legal? Thats pretty thin unless its C/M. The stuff in my bar is .130 and its beefy but ERS
Mars_302 is offline
Old 05-23-2008, 06:14 PM   #9 (permalink)
Car: 1973 DUSTER, 1997 240 HARDBODY, 2002 DODGE DUALLY
SAINT PETE
rpm motorsports 2 is an unknown quantity at this point: 10
TRY EAGLESNEST RACING IN CLEARWATER 727-536-1202 tHEY BUILD ALOT OF THE MOD MINI OR PRO 4 CARS IN THE AREA. THEY SHOULD HAVE IT.
rpm motorsports 2 is offline
Old 05-25-2008, 03:30 PM   #10 (permalink)
fails.....
Car:
norachelhere has a reputation beyond repute: 2147483647
sub'ed for future reference...
norachelhere is offline
Old 06-05-2008, 10:45 PM   #11 (permalink)
Turn 7 at Sebring
I found DOM
Jimmy Cope Racing off of 49th St N in St Pete has .095 DOM, which is usually used in cars up to 3000 lbs. He also has a mandrel bender.
Old 06-05-2008, 10:55 PM   #12 (permalink)
fails.....
Car:
thats cool. So you just buy straight lengths and the bends and weld it all up yourself, right?
Old 06-06-2008, 02:21 AM   #13 (permalink)
legend behind the cowl
Car: QR25DE B15
treekiller has a reputation beyond repute: 63642343
Quote:
Not for most sanctioning bodies. many will will require AT LEAST the main hoop to be of a single unbroken bar bent to fit the confines of the chassis.
you want the LEAST amount of welded in bends as possible. go grab a rule book for any sanctioning body, almost all of them are available online. the rules usually specify a diameter and thickness and number of points for your given class/weight.
Good Luck
Jeff Lloyd
treekiller is offline
Old 06-06-2008, 10:42 AM   #14 (permalink)
Turn 7 at Sebring
Jeff is right. The main hoop has to be one continuous bar with bends, so you can't weld straight pieces to 90 deg bends. The welds have to be top notch with full penetration. There are many rules to building a legal cage (SCCA and NASA), so get a rule book before you spend the time and money on a cage.
If your car is under 3000 lbs 1.75" x .095 DOM should be fine. If you use ERS the wall will have to be .122 because it isn't as strong as DOM. BUT, SCCA and NASA won't allow an ERS cage to pass tech, unless it was built and accepted into the cars log book before 2003.
If you are going to do any competitive racing, build a DOM cage.
Old 06-08-2008, 07:10 PM   #15 (permalink)
fails.....
Car:
I knew the main loop had to be one solid piece (i'm assuming with one weld)
I didn't think the rest of it would be a problem....
I'll have to find some rule books and find out... The original idea was to build a cage/chassis for weight and suspension.... but it might as well be legal if we're gonna do the work right?
Sponsored Links
