Forums Register TRGarage TRader Ratings Classifieds Search Today's Posts Mark Forums Read Calendar
iTrader Mainpage
Browse All Members
FAQ Gallery Weather Log Out
Go Back   Tampa Racing > Motorsports & General Tech > Chassis & Suspension Tech
Old 12-26-2007, 02:48 PM   #1 (permalink)
speed cat
Car: 240sx s13
Bradenton
Speed cat has a reputation beyond repute: 4113174
Roll cage blue prints?
I was just wondering if any one had any good sites with roll cage blue prints for pipe bending angles ect. preferably a 10 point cage but anything will do I guess. I have access to pipe and pipe bender and a buddy of mine welds I just can't find any blue prints anywhere online. Thanks guys. any info on sizing a roll cage in a car and buildign it would be good too.
Speed cat is offline
Old 12-27-2007, 01:12 AM   #2 (permalink)
Race Photographer
Car:
Mars_302 has a reputation beyond repute: 2147483647
It would probably be cheaper and easier just to order one from some company. I know the s&w are $160 for a 8 pt bar in ERS thick wall steel
Mars_302 is offline
Old 12-28-2007, 05:21 PM   #3 (permalink)
Car: 96 impreza 2 door (needs a cage), 80 corolla SR5, 00 F250
in the garage building another motor
homemade wrx has a reputation beyond repute: 26316069
the cage should be made based off of the car...I've helped with making several cages and never once used a blue print.
The safe drive cages that I've installed were loose fitting...they weren't tucked close to the chassis at all...my biggest dislike about them was the main hoop not being close to the roof or the b-pillars...really sloppy cage.
homemade wrx is offline
Old 12-28-2007, 10:09 PM   #4 (permalink)
Installs it! Builds it!
Car: Honda Accord-cowl Inducted, 351 CI Police Interceptor Air Filter with high rise hood
around Tampa Florida, Paradise
senor honda has a reputation beyond repute: 133332562
I would look at the rules for whatever class I might be racing in. They sometimes require certain things, or certain styles, thicknesses, materials, gussets and/or braces.
I want that bar as close to the car roof, and as far up from my head as possible, so if I go over, the bar hits instead of my helmet.
I would bend the pipe, so that it is almost a tight press-fit. Pre-builts
can't always do that and still have an easy bolt-on/bolt-in kit that the average bolt-on guy can install.
I would weld all the pipes fully around, even if I had to cut the roof.-Bob
Shoot an email to Ted at mkemp36297@aol.com , he builds race car chassis that run 200 mph, and can tie in the cage to the unibody for
maximum stiffness/minimum flex.
senor honda is online now
Old 01-06-2008, 08:35 PM   #5 (permalink)
KJ
bored at work
Car: 96 BMW 328i, 92 civic cx
Tampa
KJ has a reputation beyond repute: 161087488
There are rather cheap programs that you enter a couple of key dimensions into a template and it gives you the angles andlenghts between each bend. The program I use is called Bend tech EZ. Costs about $50. Works well for main hoops and stuff like that but for the rest of the car I just eyeball and measure.
KJ is offline
Sponsored Links
